Old 05-24-2010, 03:50 PM
mixaudio mixaudio is offline
Default Moogerfooger authorization requested on startup after updating to 8.0.3
Ran 8.0.3 updater and ProTools opened with no problem.
Then, also ran the plug-ins updater for 8.0.3 (Digidesign_PlugIns_Updater_v803_64447) but the updated Moogerfoger AD and RM (showing version 8.0.0) are requesting "authorization", which is present for both on my iLok.
I went to a backup and restored the previous ones I had before the update (version 7.4.2) and they worked. Do I need to request a fix on the authorization for the new versions? Is that something to be done by opening a case on tech support?
Thanks in advance.
Old 05-24-2010, 03:59 PM
Default Re: Moogerfooger authorization requested on startup after updating to 8.0.3
mixaudio did you run this Factory Bundles Update Patch for Pro Tools 8.0?
Aaron Mulqueen - 001 HD Native
Old 05-24-2010, 04:35 PM
I probably did when upgrading originally from PT 7.x to 8, but this patch would install 7.x plug-ins, which I already had (both the AD and RM before the update showed version 7.4.2).
I didn't have any problems with them in that previous version, but today after running "Digidesign_PlugIns_Updater_v803_64447" which is the 8.0.3 updater for Digidesign plug-ins, it automatically replaced the 7.4.2 with version 8.0.0 for both AD and RM.
Do you think those 8.0.0 are the same "faulty" ones that were originally installed when updating the "Factory" bundle for upgrading to PT8? That would mean I'd only need to keep the 7.4.2 ones I had before running the 8.0.3 updater.
Old 05-24-2010, 04:41 PM
Maybe AvidTechSupt or a user will chime in but I'd seek a request for technical support.
Old 05-24-2010, 05:51 PM
Thanks for the reply. I'll probably need to open a "case" for this.
Old 07-22-2010, 07:59 PM
ergalthema ergalthema is offline
Did you have any luck?
I just updated PT and now MoogerFooger isn't authorized. Pretty frustrating.
Mid-2014 15" MBP Retina 2.8GHz Intel Core i7, 16GB DDR3, OSX 10.10.5, PT11.3.1 003 Rack Factory.
Old 07-23-2010, 09:20 AM
No luck. I had to go back to install the previous version I had.
I opened a case and the response from Digi (well… Avid) was that those 2 plug-ins are now authorized together with some others in a bundle, so if I wanted authorization for the latest versions, I'd have to upgrade to that full bundle. So for now I'm just sticking to the previous versions. Sucks, huh?
Old 07-23-2010, 09:27 AM
I thought maybe I was not explaining it right, so I'm better quoting directly from their response:
"You will need to revert to the earlier versions of Moogerfooger Analog Delay and Ring Modulator in order to authorize them with the licenses you have. The newer Moogerfooger Bundle authorizes with a single iLok license - which you do not currently own. Using the moogerfooger Bundle v7.4 or 7.4.2 for Mac OS 10.5 Leopard should fix the issue."
Old 07-23-2010, 12:39 PM
The Dougfather The Dougfather is offline
Arrow Re: Moogerfooger authorization requested on startup after updating to 8.0.3
You can only use the v8 installer if the license on your ilok is mooger fooger bundle v4, if you have single ilok licenses for each plug it's the 7.4 installers.
iMac i5 2.8GHz, Macbook Pro 2.4GHz, Pro Tools 10/11, MOTU 828mk2, Presonus Digimax FS, Presonus Firestudio Project, TC Konnekt 24D
iCON Photography
Moogerfooger Analogue Delay/Ring Mod Authorization Failure jon-mark Pro Tools M-Powered (Mac) 4 05-09-2015 07:33 AM
MoogerFooger Analog Delay Authorization Problem crsync Pro Tools TDM Systems (Mac) 3 04-05-2011 10:59 AM
ProTools 9 moogerfooger plug in authorization mo_ho Pro Tools 9 4 02-11-2011 08:10 AM
Moogerfooger Analog Delay does not recognize the authorization dailan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-18-2010 01:53 PM
Moogerfooger authorization fsb1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-06-2009 08:34 AM
