Old 04-12-2006, 12:05 PM
6figgas 6figgas is offline
Default ProTools 7 w/ US-2400
Hello all. Boy have I got an issue.
OK, I have the 002r running ProTools 7. I'm using the Tascam US-2400 as my controller. For some reason it doesnt work any more. My computer see it, but when I go to set up the midi controller and assign it the tracks, I get a message that Protools dont see the device. But if I switch it when using Sonar, it works great. So the issue cant be the 2400. Also, I took this same US-2400 and put it on another computer running ProTools and it works with no issue.
Can it be the upgrade that caused this. I copied the DAE controller files from previous Protools version (6.4 & 6.7) and still no go. I also disconnect everything that I had connected via USB and just put in the 2400, still no go. Cant figure out why it works on one PC running the same exact application and not the other????? And work with Sonar 5.
Any thoughts?
Old 04-12-2006, 12:21 PM
spkguitar's Avatar
Default Re: ProTools 7 w/ US-2400
That right there is your issue. If I'm not mistaken, the US-2400 uses HUI compatibility?
Version 7 has it's own HUI drivers that are installed by default with the program. If you copied in your old ones, you over-wrote the working drivers. Delete the old drivers and try a repair of Pro Tools.
Protools 8 and tascam us-2400 nandk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 09-10-2012 09:17 PM
tascam us 2400 tutorial to configurate in protools nachonieto Pro Tools TDM Systems (Win) 3 07-26-2010 02:02 PM
Tascam US-2400 makes protools unstable? artandartists 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-16-2006 06:27 PM
Any one usig The Tascam US-2400 US-2400 Notefarm 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-14-2004 09:12 AM
US-2400 Ronni General Discussion 0 04-30-2004 06:38 AM
