since 10.3.3 all UAD plugins are going into disabled mode UPDATE & CAUSE
See posts below! Cause was CLA expansion pack for Slate Trigger causing this!! This is the first session since updating to 10.3.3 (From 10.3.2) and all my UAD plugins keep going into disabled mode? I have done a complete re-install of UAD and all troubleshooting from the Uad support pages! Any ideas? or is anyone else seeing this? Chris
Re: since 10.3.3 all UAD plugins are going into disabled mode
this is reminiscent of why i stayed in 7.4 for sooooo long... love UAD....avid get jealous i think
CAZADOR RECORDING PT10.3.10/HD6/192w16in/MTN.LION OS 10.8.5 / Westmere MacPro 8 Core W/20gRAM MAGMA-PE6R4/TDM&RTAS/WAVES Platinum/UA/Eventide Plugs/I usually record at 88.2 With GOD as my partner. . . I need to make my plans LARGER. |
You and me Jimi! I'm still on Mac 10.4.11 Quad G5 (second one), PT 7.4(cs whatever the last one was) HD7. Running all my plugs, especially my UAD 1176 TDM, which has never been equalled by anything else. Able to recall all sessions flawlessly since 2006. All my pals who play their old Fenders and Gibsons now have respect for my 2007 vintage rig ;-)
10.3.3 working perfectly here with UAD Quad.
UPDATE to the issue... Looks like this is a conflict with Slate Digital Trigger plugin. I have confirmed this by removing all plugins from the folder and replacing them back in Half/several at a time etc, without trigger in the session it is fine!! I purchased the CLA expansion pack and installed on Wednesday 2nd, plus updated to the latest version of Trigger. (But im sure i already had the latest version installed) I'll investigate further and see if i can find a fix. Chris
Nice troubleshooting! We can escalate (and contact Slate and UAD) if you don't find an update/version that solves it.
It is specifically when using the expansion pack (CLA) which can only be used with the latest version of trigger 1.66 Version 1.66 works ok when not using the expansion pack! Introduced in version 1.66 is the new auth system for the expansion pack, in settings "license settings" you navigate to an authorisation file which is stored in your trigger sounds folder. So, its only when using the expansion pack sounds! so my guess is Trigger is periodically checking the license file and when it does it knocks the UAD plugs into disable mode one at a time. after a few minutes one plugin goes into bypass, then a few minutes later another one and so on till every UAD plugin is bypassed Chris
I was just about to pull the "trigger" on the CLA Expansion for SSD4.
I think I'll wait. Good troubleshooting Chris!
Pro Tools 10.3.3 | HD Native | HD I/O 8x8x8 | Mac Pro 8 Core Westmere | 24GB RAM | OSX Lion 10.7.4 | API 3124 | Chandler TG-2 | UA 4-710d | Empirical Labs Distressor EL8X | Kemper Rack | |
Would be good if someone else could confirm this! Would like to know if its specific to my setup? computer / OS / Chassis etc Chris
to this day i continue to ask myself was it really worth the upgrade cost have sessions recall is way more valuable than avid seems to have the capacity to understand. recall is the GLORY of the digital domain...get it?
Setting Up Novation SL MkII in Advanced Mode, Automap Disabled | Napping | MIDI | 1 | 10-08-2012 03:51 PM |
Problem with disabled plugins on SC48 | raul3ear | VENUE Live Sound Systems | 2 | 08-20-2012 08:55 PM |
Boot Pro Tools w/ All Plugins Disabled | Siegfried Meier | Pro Tools 9 | 5 | 01-22-2011 08:08 PM |
Am I in record disabled mode? | Daviat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-10-2009 06:43 PM |
RTAS DISABLED IN REC.MODE? | Studiomeijer | Pro Tools TDM Systems (Mac) | 1 | 02-16-2004 12:03 PM |
