Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-30-2019, 11:21 AM
Downtown_BE Downtown_BE is offline
Default Re: 2018 Mac Mini 6 Core i7
what is BT? love my mac mini 6 core in the studio works like a charm super fast and reliable..!
Old 09-30-2019, 12:34 PM
Sardi Sardi is offline
Bluetooth.
Old 09-30-2019, 12:48 PM
Siegfried Meier Siegfried Meier is offline
Any idea as to the easiest way to hook up 27” Apple Cinema Displays (not tbolt) to the HDMI port of the mini?
Old 09-30-2019, 01:16 PM
JFreak's Avatar
JFreak JFreak is online now
DVI and HDMI are compatible so it is just a matter of buying an overly priced adapter. If you need to connect TB/DP display to HDMI then you need a converter like this.
Janne
Old 09-30-2019, 01:28 PM
27" LED Cinema Display (which I assume is meant here) is mini DisplayPort not DVI.
Maybe the question could be asked clearer "What display adapter do I need to go from HDMI on my late 2018 Mac mini to the mini DisplayPort on my 27" LED Cinema display. Or am I better off with a third party USB-C to mini DisplayPort adapter--which one?"
  #16
Old 09-30-2019, 01:49 PM
That’s exactly what I need to do...
  #17
Old 09-30-2019, 02:50 PM
...ok now you clarified your question I’ll throw this out.
I do not own a Mac Mini, so take this with that knowledge.
I would start with looking at a USB-C to Mini DisplayPort adapter/cable ... USB-C alternate DisplayPort support (at least on these Macs) means it’s a relatively simple problem to go from the DisplayPort data on those connectors to the right shaped plug. This is strictly *not* a part of Thunderbolt 3 (which yes also used USB-C connectors, and also does display stuff, ...)
HDMI needs more sophisticated signal conversion to DisplayPort, adapters will cost more and I suspect likely to be more problematic.
Ironically DisplayPort is the “native” graphics link protocol supported on that Mac Mini motherboard, it actually converts on the motherboard from that to HDMI to drive its HDMI port.
See this article for a discussion on USB-C to DisplayPort adapters for the Mac. https://www.macworld.com/article/316...pters-you.html
  #18
Old 09-30-2019, 04:25 PM
Ok, thanks man! I’ll check this out! It might just be better to get new HDMI 32” screens for the various locations where this mini is going...
Another quick question...Apple tells me that because of the new T2 chip, it’s not possible for me to boot from a USB stick/Mojave install that I’ve made (which I’ve used many times to install on several 2012 MacBook Pro machines with zero issues). They said I can only install from the Internet...which seems bizarre to me.
My connection at this time is slow, and would probably take several weeks to install if this is true...is there any other way to get Mojave on this computer right now?
  #19
Old 09-30-2019, 04:37 PM
DetroitT's Avatar
DetroitT DetroitT is offline
New build from MINI?
That's a drag. Just made a boot stick for Mojave (cMP) Both MINI and nnMP are the builds of the day for Macers.
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.10 macOS 10.14.6 APFS
Second boot-macOS 10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
  #20
Old 09-30-2019, 04:46 PM
Ummm...care to share how you did it please?
Thanks!
Sig
Mac Mini 2018 for Pro Tools...? jeremiahmoore Post - Surround - Video 5 05-13-2019 09:18 AM
Can I run 10 and 2018 on new Mac Mini? Adupr Pro Tools HDX & HD Native Systems (Mac) 10 03-03-2019 03:15 AM
PT 2018.7 Only Accesses One Core? DFT Pro Tools 2018 7 02-13-2019 09:31 PM
HDX with 2018 Mac Mini A Chapman Pro Tools HDX & HD Native Systems (Mac) 5 01-17-2019 10:35 AM
Apple Mac Mini Core i7 2GHz QUAD CORE - 4GB RAM - 2 x 500GB gsilbers Buy & Sell 3 05-18-2013 06:17 PM
