Old 08-07-2022, 08:48 AM
lesbrunn's Avatar
lesbrunn lesbrunn is offline
Default What Causes Corrupt Sessions?
Hey guys,
I've been using PT since 2000. I'm relatively knowledgeable about troubleshooting stuff in PT. In other words, I have always succeeded in troubleshooting and fixing my PT issues (which are a LOT! btw!) I know plugins can cause PT to crash depending on varying factors, but most of my issues have not been because of plugins. Over the years, I've had more than my fair share of corrupted sessions, of which the recommended solution is to import tracks one at a time into a new session. This procedure is ridiculously time-consuming if it's a big session. We all know how slow Avid is to conform to modern norms. This is my question: Apart from plugins, what are the things that corrupt sessions? What causes a perfectly good session to suddenly misbehave to the extent where the only solution is to import tracks one at a time? BTW, it's well known that other DAWs don't do this. Upon opening a session, almost every other DAW will pinpoint incompatible plugins and save you valuable time. Thanks, guys. This is knowledge that cannot be obtained anywhere else...
MSI Pro Z790 Edge | i913900k @ 5.7GHz | 64GB DDR5 5600| 8TB NVMe | 3TB SATA SSD |10TB WD Black | Audient iD14 | PT 2022.12| Win 11 Pro | Tons of VIs and plugins
Old 08-07-2022, 09:19 AM
peapodpost peapodpost is offline
Default Re: What Causes Corrupt Sessions?
for a while in the PT 2018.XX range I was highly suspicious that using clip effects could corrupt a session.
Old 08-07-2022, 09:41 AM
While possibly a rogue plugin, my first suspect would be hardware (RAM, disk subsystems, etc) - on a well-tuned system I'd say corrupt sessions are extremely rare; I've been a PT user since there was PT, pretty much 8 hours a day 5 days a week, and I can't remember if I've ever had a session become corrupted - maybe two or three over the years - I mean there's thousands of these rigs out there on dub stages, production suites, tracking rooms running round the clock that have very few of these kinds of problems. I'm not a VI user, but otherwise extensive use of plugs.
If this is a regular occurence then there's definitely something wrong and some real troubleshooting is required - it's not like this is an accepted and regular occurrence on Pro Tools systems.
Members who maintain and troubleshoot multiple rigs (i.e. post suites, etc) may have more specific suggestions.
http://www.richbreen.com
Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock
Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6
Old 08-07-2022, 09:47 AM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by lesbrunn View Post
Hey guys,
I don't know the cause BUT I have use PT since 2003 and much the same the biggest issues for me are corrupted sessions. But thankfully not that many really, only a couple that needed to reimport tracks and could not be fixed by closing and exiting PT,,,, Trashing PT preferences ,,and rebooting PT ..Which I try first before importing to new session.
System :
Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1
Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2024.3.0 --Sonoma 14.4
Enjoy the Journey
.... Kev...
Old 08-07-2022, 01:04 PM
nednednerb's Avatar
nednednerb nednednerb is offline
I have had corrupt sessions with any kind of regularity only in two situations:
1) Copying sessions from Hackintosh PT systems at audio school studio into my home system and back to the studio. This is when I was a new user around 2010.
2) Opening some sessions on my MacOS system where I was (foolishly) using Dropbox to backup sync my working folders.
I no longer deal with Hackintosh systems, or use Dropbox, and since then I rarely if ever run into a session problem that, echoing others, a reboot/power cycle etc does not fix.
___
>> me: nednednerB //
||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music //
||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 //
||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock //
||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR
||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts //
Old 08-07-2022, 01:50 PM
grayter1 grayter1 is offline
Dropbox and PT can be thorny, but I use it daily as a secondary backup in PT, Nuendo and Studio One without issue. When I've had an issue, it's always been with PT, but it's a rare occurrence. The other DAW's mentioned all work perfectly using Dropbox as a back up. As usual YMMV.
I also agree with your Hackintosh assessment. I used one for many years and things were always iffy. Once I went back to regular apple hardware, those issues went away.
tg
Mac Studio (2022) M1 MAX / 64GB / 2TB HD / macOS Ventura 13.6.5 / RME BabyFace Pro FS / SSL UF8 + UF1 + UC1 / Roland SYSTEM 8 / Kontrol S61 mk3 / Pro Tools Studio 2024.3 / Nuendo 13 / Reaper 7 / Komplete 14 / Omnisphere / Keyscape / Trilian / V Collection X
Old 08-07-2022, 03:37 PM
Eric Lambert's Avatar
When importing from a corrupt session to a new one I don't go track-by-track, I do the whole enchilada. At the point of corruption, the issue is no longer a problematic track (i.e. plugin), it's the session file itself. Or so has been my experience and that of my company in general.
I'd also have to echo what Rich said about the lack of corruption when the system is well maintained and the workflow isn't inviting to errors. Once I became uber strict about plugin and computer maintenance, corrupted sessions essentially dropped off the planet. We have a couple guys who tend to see a few, but they're also the same guys who do the least to keep on top of maintenance.
Why do they happen? Several reasons that I can think of. I'd estimate that many happen when ProTools is saving the session file while there's an interruption of some sort that causes an improper save. It might be PT communicating with the file (this is where I'd look at plugins as the culprit), or it might be a drive or OS issue.
Old 08-08-2022, 03:07 AM
dominicperry dominicperry is online now
Useful post from Jeffro at Avid regarding running sessions from Dropbox folders.
Originally Posted by jeffro View Post
Check out resources.avid.com/SupportFiles/PT/Pro_Tools_Reference_Guide_2022.6.pdf#G12.1265071 for info about the Cloud Storage Services options in Setup/Preferences/Collaboration.
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 08-08-2022, 10:29 AM
lesbrunn's Avatar
That makes sense and would save valuable time.
Old 08-14-2022, 09:40 AM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
I wouldn't consider myself an expert but I have been a user since PT 5, Mac and PC. The few times I have had corrupted session issues (I always had backups on other media luckily) testing I ALWAYS found it was either a single corrupt plugin or track file or a storage issue
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Why Do Sessions Become Corrupt? lesclinton Pro Tools 11 4 09-15-2014 12:07 PM
Corrupt sessions?? Audioartist Pro Tools 10 1 11-01-2013 02:18 PM
Corrupt Sessions ichbin Pro Tools TDM Systems (Mac) 9 11-29-2009 10:56 PM
Corrupt Sessions! secondspassed 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-18-2003 12:02 AM
Corrupt Sessions, HELP!!! Last 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-04-2002 02:02 AM
