Old 06-08-2022, 12:01 PM
nymills nymills is offline
Default Install Issue W10 & PT Studio 2022
The menu area across the top of PT is not fully visible. It's blocked by other work area windows and can't be rearranged. Not had this happen in the past with PT versions until the last two. What's the best solution?
Also, tried uninstalled to install just on this machine. It won't uninstall and when opening or trying to uninstall it's looking for an external database. How can I change that?
Thank you!
Old 06-08-2022, 12:27 PM
Default Re: Install Issue W10 & PT Studio 2022
Sorry, but none of this is making a lot of sense. Maybe in your frustration, you are not being clear? In any case, please start over and include full system details. Right now, we know absolutely nothing other than you might be on a Windows machine(people have been known to post in the wrong section, so its not a big deal, but without full info, its tough for anyone to help).
Having said that, here is the method to uninstall Pro Tools from Windows 10:
1-Right-click on START and select Apps and Features
2-in the upper right of the next window, click on Program and Features
3-let the list fully load, then scroll to Avid Pro Tools
4-Right-click on Avid Pro Tools and select Change
5-follow the prompts to remove Pro Tools
You have the option of removing ONLY Pro Tools, or also removing prefs, database, etc. If this is a new install(not an update to an older version), then it may be best to select the option to remove all the extra stuff(since you have not made a bunch of settings yet).
Old 06-08-2022, 01:33 PM
64GTOBOY's Avatar
64GTOBOY 64GTOBOY is offline
Thank you!
Also make sure "run in compatibility mode is unchecked.
Dell XPS 8900 i7-6700K CPU @ 4.00GHz 64 Gig Memory:Seagate 2x 2TB, 4TB,500gb EVO OS Windows 10 pro
PT 2023.3 Studio through an A&H Qu-32
Old 06-09-2022, 07:22 AM
nsureit nsureit is offline
Try changing your screen resolution.
Old 06-13-2022, 09:25 AM
Thank you everyone for your reply.
I AM on W10 Pro. I have two issues.
1. The menu or nav bar across the top of PT is not fully visible. Please the attached image. It's blocked by some other window. I've tried rearranging. Resizing the display resolution, etc. This has not happened with previous PT versions. Running 2022.5
Tried uninstalling, but PT app uninstall is grayed out. Are there other programs/apps that require uninstall first?
2. Seems the programs database is connected to our external raid array. When working remotely it won't allow PT to fully and function and keeps asking for that drive/array system before opening. Is there a way to re-designate the drive?
Thank you!
Old 06-13-2022, 11:22 AM
Saying you are on Windows 10 is about 1% of "full system details" Given the pic you posted, now we also need to know the screen size and resolution and if you are using any scaling(I run 100%, or no scaling and have never seen this, but I have seen it from other users). It may be worth updating your graphics driver(but if its nVidia, get the drive from nVidia, instead of the card maker). Sorry I can't help on the drive issue, but that's above my pay grade
Old 07-01-2022, 06:48 AM
Computer specs are well up to speed. nVidia RTX5000, 128GB ram, UHD 4k DreamColor Monitor.
No matter the resolution setting, the issue continues.
As I've stated before, but seems to overlooked in this thread is this didn't happen with previous versions of PTs. An upgrade to 2202 has seemed to cause this.
Any thoughts?
Old 07-01-2022, 02:44 PM
64GTOBOY's Avatar
Thank you!
IME this is always from having "Run in compatibility mode" checked
Old 09-07-2022, 10:19 AM
"Run in compatibility mode" is unchecked.
Nvidia RTX drivers are up to date. Installed PT studio 2022.7. Changing resolution size does not fix the issue. As stated before, this did not happen with pre-2022 versions.
Really need this working for our Avid post workflow. The current issue makes it very difficult or near impossible to use.
Could this be an installation issue?
Anyone have any thoughts? Thank you!
Michael
Old 09-07-2022, 12:20 PM
Hmmm, Can you try running at 1920x1080 as a test? PT is still not optimized(AFAIK) for 4K screens
Pro Tools 2022.4 on Mac Studio M1 Ultra Selle Sellink Pro Tools 47 06-05-2023 01:42 PM
Studio 2022.4 Synchronization Preferences Missing? StefB Pro Tools 0 05-19-2022 06:48 AM
Need to install Avid Control App 2021.10 for iPad and not latest 2022.4 virtualG Avid S1, S3, Dock and Control App 8 05-06-2022 12:13 PM
PT 2022 Studio with MBP mid 2012 NeoAle73 Getting Started 0 04-27-2022 12:27 AM
