Old 06-10-2021, 06:33 PM
PTPerson PTPerson is offline
Default EQ and DYN panels not showing plugins
Howdy,
I've just started having an issue with the EQ and DYN panels on my D-Control.
The system appears to be communicating, track names are showing, but no plugins are coming up.
Any thoughts?
Thanks,
Stefan Nowak.
Old 06-24-2021, 02:01 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: EQ and DYN panels not showing plugins
Originally Posted by PTPerson View Post
Howdy,
Any thoughts?
Thanks,
Stefan Nowak.
I had this happen once and i had to re-install PT and that fixed it.
You could try trashing the PT prefs to see if that works but a fresh install of the program is you're best route. obvously trash all prefs at the same time as you re-install PT.
Unless it is an actual hardware issue in which case the ribbon cables.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-28-2021, 08:36 PM
Led Led is offline
Anything happen if you hit the window button in the eq or dyn centre section?
Old 07-12-2021, 12:41 PM
Sorted this, when I recalled that it happened before.
It's a crazy one!
It appears that I had an external drive connected to my computer that had a 'User' folder in it somehow... this reeks havoc with plugins for some reason, not allowing saving or preset options.. it also hindered EQs and DYNs showing on the panel.
Once I ejected the disk all came back to life.
Crazy!
Old 07-12-2021, 09:34 PM
Led Led is offline
It's like the old cd in the tray thing that used to stop PT maximizing after you minimized it. My D Command crashes PT on startup if I have my TV switched on that's connected to my onboard graphics via HDMI. What a time to be alive.
Old 07-13-2021, 08:19 AM
arche3's Avatar
arche3 arche3 is offline
Holy crap. Lol.
Sent from my SM-G986U using Tapatalk
PT 11 HD with HDX plugins not showing up garnoil Pro Tools HDX & HD Native Systems (Mac) 7 09-28-2013 04:02 AM
New TDM Plugins Not Showing Up SPA Pro Tools TDM Systems (Win) 3 03-01-2010 06:07 PM
My AIR Plugins are not showing up! PUPO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-21-2009 04:41 AM
Old plugins still showing... digifriend 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 05-14-2009 02:21 AM
Plugins not showing up Royalston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-03-2006 01:58 PM
