Old 01-31-2021, 06:20 AM
Will Russell's Avatar
Will Russell Will Russell is offline
Default D-Command/Control and MDW-EQ6 band solo
Hi all,
Question for D-Command/Control users who also have the recent MDW-EQ6. Do you have the ability to turn the band solo feature on and off on the control surface? MDW-EQ5 had this when you spilled the EQ out to rotary encoders but I cant seem to find the function with MDW-EQ6. Anyone?
Will Russell
Electric Wilburland Studio
https://linktr.ee/wilburland
M1MAX Mac Studio OS 14.4.1, PT2024.3, HDX, S1/Dock
M1 PRO MacBook Pro OS 14.4.1, PT2024.3, BabyFacePro FS
Old 02-08-2021, 08:50 AM
PTPerson PTPerson is offline
Default Re: D-Command/Control and MDW-EQ6 band solo
Absolutely.
In fact before buying the upgrade I asked this very question.
You can iso peak if the plug in is inline or via custom faders.. ie - not on the EQ panel.
I think the button may have changed in V6 - it's on one of the GAIN encoder's buttons now, I recall it being different on V5.
Old 02-08-2021, 09:02 AM
Is the right side button under the GAIN encoder lit?
Old 02-08-2021, 09:35 AM
Under the master gain, yes. That bypasses the plugin
Under the band gain, nothing lit, buttons do nothing
Are you on a D-Control or D-Command?
Will Russell
Old 02-08-2021, 01:45 PM
D-Control here. I would have assumed that control would be similar.
Have you tried mapping yourself? In the pull down menu on the Plugin, is there an option to map isopeak?
Stef.
Old 02-08-2021, 02:03 PM
Stef.
Thanks for adding your brain to this. There is no option to map isopeak. Is there on your rig? Im running version 6.0.3r27
Will Russell
Old 02-08-2021, 02:05 PM
Shall let you know ASAP
Old 02-08-2021, 03:30 PM
Here are all control parameters available here.
Old 02-21-2021, 04:04 AM
Yup. Same as mine. So there is no control for band solo?
Will Russell
Old 02-21-2021, 12:31 PM
I don't understand..
The band solos are there so therefore can be mapped.
Key command for clearing playlist solo? reichman Post - Surround - Video 10 02-24-2023 11:52 AM
What happened to the band solo buttons? quadraphonics Avid S4/S6 4 04-19-2019 07:09 AM
EQ 3 7-band solo feature not working bluesguy76 Pro Tools 12 4 12-17-2018 02:44 AM
Going from solo bedroom DI to recording full band? De93 Pro Tools 10 1 11-23-2011 07:55 AM
Digi EQIII 7-band and Command 8 jimlongo ProControl, Control|24, Command|8 1 06-23-2005 02:44 PM
