Old 11-10-1999, 04:18 PM
Paul Alvarez Paul Alvarez is offline
Default Internal SCSI HD Performance in G3
I will be using the Digi001 with a beige G3 300MhZ (I've seen the known bug info). My question regarding the hardware is:
The beige G3 is "plumbed" for a second SCSI internal drive. If I get a large capacity internal drive from the list of Digidesign recommended manufacturers, will the performance be adequate?
If not and I have to go the route of an external HD, I was told today by Sweetwater that I might need a high speed SCSI card because of data transfer performance requirements and because the standard SCSI connector on the back of the G3 is different (68 pin on the drive vs. 50 pin on the CPU).
Any insight on this from anyone?
Thanks,
Paul
Internal SCSI Cables DocDolby Pro Tools TDM Systems (Mac) 2 06-02-2008 02:43 PM
Internal SCSI Drives for 001? What is best???? Jail Records 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-26-2002 06:40 PM
Using internal SCSI and ATA? mrhappy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-28-2002 07:54 AM
Internal SCSI Paullynch Tips & Tricks 0 07-18-2000 07:40 AM
G3/266 internal SCSI? beautyfish Storage Subsystems 1 04-20-1999 07:26 PM
