Old 11-06-1999, 09:07 AM
evanb evanb is offline
Default ADAT Transfer to 001 using MTC
Since PT 5.0LE will send MTC and receive MTC, is it be possible to do digital ADAT transfers in time using an interface like the 64XTC?
I know that I won't be able to view it in SMPTE but will it lock consistently anyway?
I know the 2408 does this seemlessly. Also, is the ADAT I/O on the 001 24 bit?
[email protected]
Old 11-06-1999, 09:16 AM
Joncon Joncon is offline
Default Re: ADAT Transfer to 001 using MTC
I'm not sure about the 64XTC in particular but you should be able to lock up an Adat consistently with an external Adat sync box.
Yes, the Adat I/O is 24 bit.
Jon
Old 11-06-1999, 09:48 AM
Jon-
Do I *have to* use the 001 as my MIDI interface? If I can just use the 64XTC, I'm in business.
evanb
[email protected]
Old 11-06-1999, 09:56 AM
carlone carlone is offline
You don't have to use the 001 as your midi interface, you can use any interface that OMS can deal with. You can even use both your 64xtc and the 001's midi interface together at the same time.
Adat to PT 001 transfer ? new engineer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 05-11-2005 07:29 PM
ADAT transfer help thermal Pro Tools TDM Systems (Mac) 5 12-06-2002 08:03 AM
adat transfer 8mmOverdose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-12-2002 03:10 PM
ADAT Transfer? bombayentertainment General Discussion 1 05-15-2002 12:57 AM
ADAT transfer using 001 dsmalls 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-07-2000 04:35 PM
