Old 11-03-1999, 11:59 PM
Jake Landau Jake Landau is offline
Default Digi 001 inserts...
Is it possible to record with RTAS plugins ( like a compressor), so you wouldn´t have to use so much computers memory in the playback ("I don´t know much about these things.").
Jake
Jake
Old 11-05-1999, 05:50 AM
carlone carlone is offline
Default Re: Digi 001 inserts...
Yes, you can record thru whatever plugin you want. That's a good way to save some plugins for the mix. Make sure you get the sound you want before you record of course.
Old 11-05-1999, 09:08 AM
ProdInfo ProdInfo is offline
Jake--
The routing options in Pro Tools are very powerful and they allow you to record with or without a plug-in. Or, record without a plug-in, then add it on later and route this to a second track and record it with the plug-in. This frees up the DSP, and it also gives you the option of going back to the unprocessed track if you decide to make changes.
Ted
Outboard Inserts with Digi 002 kheftel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-07-2009 03:15 PM
Inserts Question for Digi. SoundEng1 Pro Tools TDM Systems (Mac) 11 12-26-2005 02:10 PM
Using Hardware inserts with the Digi 002. pottsdrum 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-25-2004 08:44 PM
Digi 002 plug-ins, inserts DaleB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-06-2004 07:01 PM
No inserts on Digi 002? Marzuki 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 11-04-2002 07:21 AM
