Old 08-23-2010, 12:17 PM
keithaska keithaska is offline
Default Sandra Report
OK,
Just installed a new CPU because the Sandra report could not get past the CPU Arithmetic part. The computer would completely shut down. So now it's gets past the CPU section and when it gets to the power section it sits at 8%. That must have lasted about 10 to 15 minutes. Should I let it go or does it sound like a need a new PSU?
Ideas...anyone?
Old 08-23-2010, 12:19 PM
Dism Dism is offline
Default Re: Sandra Report
Originally Posted by keithaska View Post
OK,
Ideas...anyone?
Yikes.
Does sound like you need a new PSU... but what are the basic specs of your computer? Win version?
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 08-23-2010, 12:28 PM
PC Spectral 7100-
XP Pro - Sp2
ASUS P5G14-M Motherboard
Dual Core Pentium E6500 (LGA775)
3.00GHz - 4GB RAM
Digi 003R 8.0.3
Old 08-23-2010, 12:31 PM
PC Spectral 7100-
XP Pro - Sp2
3.00GHz - 4GB RAM
Digi 003R 8.0.3
Well for starters... Sp2 expired a long long time ago. Everything built within the last couple years has been written for sp3, including Pro Tools. 8.0.3 isn't technically qualified for sp2, either.
If I were you, I'd clone my drive and try updating to sp3. If that doesn't help, a new PSU is probably in order.
D
Old 08-23-2010, 12:36 PM
OK, I give it a whirl.
Old 08-23-2010, 12:43 PM
tcbetka tcbetka is offline
I had XP Pro, SP3 on a hard drive and tried running Sandra before. It would shut the machine down with a BSOD, lol. It wasn't until I moved to Windows 7 that I was able to run Sandra. I have no idea what was causing the issue though--the XP Pro edition I was running was shipped with SP3.
TB
Craviotto acoustic drums
Audix drum mics
Intel Q9450 Quad-core, 8GB RAM, W7 Pro 64-bit
Macbook Pro 2.66GHz i7, 4GB RAM, OS X 10.6.6
Mac 2.0GHz G5, 4GB RAM, OS X 10.5.9
Glyph 500GB, 120GB external hard drives
sandra report vin7 Windows 3 03-26-2014 03:47 PM
Sandra report mickeyrouse Getting Started 3 01-13-2014 05:57 PM
Thanks! Sandra Report stevegrisham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 07-08-2009 09:26 AM
sandra report manyrains 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 10 11-08-2007 09:55 AM
Sandra Report Help Please JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 04-09-2007 05:52 AM
