Old 10-13-2009, 11:49 PM
scottleader scottleader is offline
Default 8.0 cs3--Dont hear take while recording...
So, besides the butt load of weird "assertion" errors, crashes, spinning wheels and other BS that has killed my productivity since I moved to PT8, all of a sudden, when I am recording I sometimes do not hear the take even though the wave forms show up on the track...
Any thoughts?
Thanks-
Old 10-14-2009, 01:49 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: 8.0 cs3--Dont hear take while recording...
Any thoughts?
Thanks-
If you're getting so many problems then its time for drastic troubleshooting.
Uninstall PT.
trash all prefs and database files using this app.... .http://duc.digidesign.com/showthread.php?t=190122
Reboot the mac
install new download of PT8
Install 8.0.1 update
MAKE SURE ALL PLUGINS ARE UP TO DATE AND COMPATIBLE!!!!
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-14-2009, 07:42 AM
*sigh*
Chris, I think you are correct.
I fear 8.0.1 though, based on reading the posts on here.
Old 10-14-2009, 08:44 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
I too have had this in cs3. Makes one look somewhat of a a plum!
cheers
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 10-14-2009, 08:52 AM
Siegfried Meier Siegfried Meier is offline
Ummm, this has been happening since PT7 at least, if not earlier - I'm sure most of you have come across it if you're tracking a lot of records. Been here forever, annoys the crap out of me and the artist always thinks that I haven't put it into record.
Sig
Old 10-14-2009, 08:58 AM
Seems worse in 8 to me
cheers
cheers
BAFTA member
IPS member
Old 10-14-2009, 09:07 AM
Its much worse in 8. I could go two weeks 10 hours a day with 7.3 and no issues at all. Now its something every hour of every day.
I have checked plug ins, settings, trashed prefs, reinstalled, etc etc etc... I have spent hours on the phone with tech support. (And paid for it I might add which makes me sick to my stomach.)
Digi. I beg you. Please. You can keep my money I paid for the upgrade but please return my old 7.4 authorization. I beg you!
I can not work like this anymore. I am like a week away from selling all this shiz and learning Logic. My client's are getting annoyed at the constant restarts and crashes and honestly, it makes me look like I don't know what I am doing.
Old 10-14-2009, 11:15 AM
audioluche audioluche is offline
Scott, you should have your 7.4 authorization on your ilok if you did not sell it.
I purchased v8 a couple of weeks after it came out and i'm still on 7.4, v8 has been too unstable for me. Did not had the time to search too much either, so that's why i'm still on 7.4.
But i have the bug you'r talking about once in a while (maybe once per 2 weeks) in 7.4. For the rest it's rock solid.
Luc
Old 10-14-2009, 02:44 PM
DigiTechSupt's Avatar
Scott - I'm finding that, all too often, the crashes and other problems are caused by various misconfigurations. Plug-ins are a BIG factor - I will direct you to this thread where you will see much of the same complaints resolved by removing/updating incompatible plug-ins and a few other reconfigurations:
http://duc.digidesign.com/showthread.php?t=256039
I have several other DUC threads very similar to that. I've also done direct troubleshooting for several customers, all who are working fine once we configured things properly.
I would strongly recommend going through your plug-ins and making sure they're not compatible, removing or updating ones that aren't. If it's not on the list, assume it's not compatible.
Trash preferences after doing so so that all plug-in data can be re-cached.
Pro Tools Plug-In Compatibility Grid
Also, verify that you've done the optimizations and troubleshooting from the General Troubleshooting thread, as that often has improved stability for many customers.
Avid Audio Tech Support
Support FAQ
Old 10-14-2009, 03:13 PM
WernerF WernerF is offline
Scott, I of course believe you when you say that you are having all of these problems. The flip side of this is that, in my case at least, I have been running 8.0.1 since it came out and have been tracking drums, bass, guitars, vocals, horns and doing a bunch of editing with not a single problem. I did what was suggested and made sure that all of my plugins were up to date before installing even the 1st version of 8 and have had no problems with anything. I've even used a few VI's, Ivory, B4II, Melotron Pro etc and things have been going great.
Chris is right, you might be surprised to find out that things end up going a hell of a lot better after checking for and correcting compatibility issues.
Can't hear track I'm recording on but can hear all others Durstlaw 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 19 12-14-2022 01:24 PM
dont want to hear guitar amp while recording Sushidude Eleven Rack 9 09-04-2011 01:41 PM
Pro Tools shows signal but I dont hear anything??? drumzalicious 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-22-2010 11:30 AM
Help...Why dont I hear anything out my speakers cristol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-22-2007 10:34 PM
MBOX dont want recording via S/PDIF in 48/24 blacksunrise 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-11-2006 12:37 PM
