dverb test on powermac g5
anybody ever do a dverb test on a powermac g5 ppc dual 2.0ghz? im thinking about getting one to replace my macbook but i dont know if it would perform better
Re: dverb test on powermac g5
U don't kno what u want hunh
not really, i've been using the laptop for almost 3 years and it works great for mobile recording. im able to get 18 tracks to the external firewire drive via 003 and a yamah 01v. ive gone 2 hours and 15 minutes straight with 18 tracks with this setup. the problem is with mixing these live shows yu have to edit the crap out of them and use tons of eq because theres bleed everywhere. so i just need something with more power for mixing on, preferably a mac so that i can transfer the files easily.
im starting to think if an old powermac g5 with some uad cards would work out better than a pc. |
Leopard will not run on the PPC and based on Digi's recent announcement, neither will the next release of PTLE
but I bet they'll be cheap
Stainless - G5 2.3x2, 5 GB RAM, 1.5TB, OSX 10.5.x and 8.0 002R/D8, MC Control/MC Mix, etc, etc, etc |
& too, transfers are just transfers...Doesn't matter(since v7) what platform ur on actually...
leopard definitely works on g5 and the rumors of snow leopard not are bringing down the price which is why i want to buy one.
First off... what are the specs of the Macbook you are running? Is it a MBP? Intel? RAM? etc...
Second... a G5 is hardly an upgrade, at this point. Speaking as a G5 user, I'm really not happy with the current performance, and I find myself having to switch sessions over to my Macbook Pro more and more lately. The problem is the processing. Single core is out, multi-core is in. Not only are they far more efficient, but most new software is being designed with multiple cores/cpus in mind. The G5 I'm running has a 1.8GHz with 6GB of ram, and it can barely handle a solid mix session without a lot of lag. I switch over the session to my 2.2GHz Core2Duo, 4GB RAM MBP, and it runs smooth as silk. G5s are cheap right now for good reason... they're outdated. Finally... You mentioned you use a 003, and an 01V. That's at least $4-5,000 combined, if you bought them brand new... but you don't want to invest in a decent computer? Get a Mac Pro, rather than G5, you'll be MUCH happier, and a Mac Pro will last you at least a few years, whereas a G5 is going to be mostly obsolete within the next 6-12 months. |
Look here: http://www.digidesign.com/index.cfm?...4&itemid=39673 Even though the G5s run Leopard, you may want to reconsider any future with them.
PT 2024.3 DP 11.31 VEP 7.x with various VIs NI Komplete Audio 6 on HP Envy 8G i7 Quad Laptop Win11 MOTU 828es ADA8200 MTP-AV on HP Z2 G4 Xeon Workstation Win11 MOTU M4 on MacBook Air M2 2023 Sonoma.4.1 |
Can you give an example of how much plugin activity you can use before your power gets low?
"I'm not really HoboSoul™, but I play him at the DUC..." Mac Pro 12Core 3.46G (5.1) | 64G Ram OSX 10.11.6 | PTHDN/OMNI/Apogee Duet(non Avid) 10.3.6 / 11.3.1 Need mixes, mastering, guitar, keyboard or bass parts added to your tracks? Need custom songs/music written and produced for special occasions? Check out The Soundz Shop. Great work by pros with multi-platinum experience at excellent prices... |
Very basic plugins running. A compressor on each track, maybe an EQ... in a typical session of about 20-30 tracks. Runs sloooow on the G5, while the exact session runs beautifully on the MPB. Can't even run more than one instance of Eleven without seizure. Just one instance of Ozone brings performance down significantly, even in a session with less than 10 tracks. Performance settings are maxed out in Pro Tools as well.
Should I still do a DVERB test? | PeterGreen | Pro Tools 10 | 9 | 01-05-2013 07:20 AM |
Dverb test pt 10. | acer | Pro Tools HDX & HD Native Systems (Win) | 10 | 03-07-2012 03:08 PM |
Dverb Test Help... | shawnames | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-14-2009 03:10 PM |
DVERB test help | synchronic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-08-2009 12:26 PM |
Dverb test How it is | flautista | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 04-13-2004 03:39 PM |
