Old 03-21-2007, 07:15 AM
Default v7.3.1cs2 - Two (2) Video Related Issues
My system: Quad 2.5GHz G5, 4.5GB RAM, OS X v10.4.8, HD|2 Accel, 192 I/O, SYNC I/O, Keyspan USA-28x, SIIG FireWire card (the qualified one), Mojo SDI
Issue 1 - After loading in 1.75 hours of audio and video, I got an error and couldn't revive the lost video clip (which has happened before), which resided on it's proper drive (a drive other than the audio drive or Macintosh HD) taking up 16.5 gig. Another similarly configured system experienced a similar glitch, but WAS able to drag the file back into Pro Tools and use it. Unfortunately, the video file was somehow corrupted... so I had to start all over again for another 1.75 hours.
Issue 2 - Dragging a DV stream into Pro Tools and dropping on the video track resulted in the WRONG CLIP ending up on the time line. The session continued to reference the same file on a different disk attached to the system. Even though we were dragging the correct file to PT- the video track wouldn't stop thinking it was the same file from its previous location. This caused massive confusion for all during the session. The solution seems to be to bring in video via the "import" command rather than dragging and dropping.
Has anyone else had this happen to them? Any information on these issues would be appreciated.
Thanks for reading!
Old 03-21-2007, 08:14 AM
DigiTechSupt's Avatar
Default Re: v7.3.1cs2 - Two (2) Video Related Issues
1. What is the error message that you got?
2. Yes, this is a known issue and is logged for a fix.
Avid Audio Tech Support
Support FAQ
Old 03-21-2007, 11:21 AM
jeremiahmoore jeremiahmoore is offline
Yes - I've seen the wrong clip thing nearly daily...
Workaround is to use "Import / Video" in File menu. Cmd-Opt-Shift-I
-jeremiah
Old 03-21-2007, 03:27 PM
I wasn't operating the system at the time, so my information is sparse. Error messages included phrases such as "picture playback error" or "bus error". When the engineer tried to import the video file that was recorded but not placed upon the timeline when stopping, the error message essentially said "sorry, there are no video frames in this file".
We are anxiously awaiting v7.3.1cs3! Thank you for the information.
HTML code is On
Internal HD related issues? tjacob Storage Subsystems 4 11-17-2010 02:48 AM
Audio Clock Issues in PT 8.0.1cs2 XP Pro SP3 cornhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-19-2010 09:26 AM
Losing Video Output - 7.3.1cs2 NTK Pro Tools TDM Systems (Mac) 13 07-07-2007 10:18 AM
Plug In Issues on Intel Mac - 10.4.8 - 7.3.1cs2 jkess Pro Tools TDM Systems (Mac) 1 03-26-2007 11:22 PM
Issues Installing 7.1cs2 laki Pro Tools TDM Systems (Win) 5 12-23-2005 05:37 PM
