Old 10-28-2000, 07:57 PM
nettwerk nettwerk is offline
Default No output to 1622 *and* master fader shows output?
I just got a 1622 and am having some difficulty with it.. any help would be appreciated...
When playing back a score/waveform/whatever, my master output fader shows output, however the 1622 does not seem to notice it. Furthermore, when i put a valid input signal on one of the 1622 inputs, the PT mixer channel monitor does not show any input. My hardware settings are setup as such in the hardware config window:
mix card 1:
interface port - A
sample rate - 44.1k
sync mode - internal
ch 1-2 - analog
any help would be great..
thanks
btw this is a 24/mix+ system on dual g4 500 mac.
Old 10-30-2000, 05:35 AM
DigiTechSupt's Avatar
Default Re: No output to 1622 *and* master fader shows output?
-Reseat the interface cable, at both ends, checking for bent and/or broken pins
-Trash the DigiSetup File from the System Folder>Preferences folder, empty the Trash and restart the computer. When you go back into Pro Tools, do so from the Pro Tools Application Icon and not by double clicking on a session. Once Pro Tools is launched, reconfigure the hardware settings.
Brent
Avid Audio Tech Support
Support FAQ
Master fader final output level bryced87 macOS 5 04-22-2013 05:10 AM
master fader output w/ headphones one willl3 Pro Tools HDX & HD Native Systems (Win) 1 12-29-2012 06:42 AM
Output level/Master Fader conundrum... jensen5 Pro Tools M-Powered (Mac) 2 05-30-2005 10:41 PM
Clipping at A/D shows up on master fader? soundispatch 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 23 04-24-2005 09:13 PM
Routing output of master fader MPB 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 12-14-2003 12:44 PM
