Old 06-15-2006, 07:37 AM
zerovu zerovu is offline
Default edit window & timecode freezes intermittently
While recording audio and video (mojo, sync with house vid ref and timecode) occasionally the edit window scrolling and timecode window will freeze for about ten seconds and then pickup with apparently no problem with recording. Typical sessions are 1 to 2 hour recording sessions. Anybody else see this issue and or how to keep my heart from stopping when this happens? Generally using page scrolling mode. System limit is set to 2 hours. No other apps open. Very clean system. Setting BWAV 16 bit 48Khz. 8 to 22 tracks.
Thanks
MAC OS 10.4.3 8 gig ram
G5 dual 2
PT 7.1 (3 -192 & sync IO)
Internal 250 drive ( not system drive) for video
3 (120 gig GLYPH drives for audio)
Old 06-15-2006, 08:12 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: edit window & timecode freezes intermittently
Quite common with lots of users!! autosave or spotlight?
Chris
Producer, Engineer,
www.ukmastering.com
Mix Window Freezes but Edit Window works fine. wwicklund 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 07-10-2022 10:57 AM
MC Control v2 Jogwheel use freezes edit window ronnievanoverveld Artist Series 3 09-09-2011 05:11 AM
edit window freezes while recording pisound Pro Tools TDM Systems (Win) 3 04-01-2010 08:30 AM
PRO TOOLS SCREEN FREEZES INTERMITTENTLY! Torchlight 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-15-2006 10:22 PM
Edit window freezes during playback 4times4mil 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-11-2006 09:35 AM
