Which KVM Extender? (USB,VGA,DVI,PS/2, Firewire)
I would like to move my computer out of the "control room" and into a walk in closet, but am confused by the myriad of choices and specifications. For example, I've read that firewire cable should be no longer than 15 feet, but Markertek sells firewire cables that are much longer.
What do I really need? What works best? I'm only moving the computer about 25 feet away. Thanks! |
Re: Which KVM Extender? (USB,VGA,DVI,PS/2, Firewire)
OK, I found some information using search:
Apparently, some users have had success with 30' firewire cable found here: http://www.firewirestuff.com/cables1.html IntelDoc suggested a Belkin solution, perhaps these: http://web.belkin.com/config/Search/...tender&catID=1 I was looking at this: http://www.gefen.com/kvm/product.jsp?prod_id=1873 There are also the crazy-expensive fiber solutions, but I don't have that kind of cash. |
I like Belkin and Raritan.
Try looking here http://www.tigerdirect.com/applicati....asp?CatId=202 They have every possible KVM solution and I've ordered from them for years with no problems.
www.carvelstudios.com |
I like Belkin too, but I think the original poster is confused. If he's just moving his single computer to a closet, he doesn't need a KVM switch, just extender cables for monitor, keyboard and mouse.
Cheers,
The Weed wrote, "I like Belkin too, but I think the original poster is confused."
OK, I admit it. What does KVM stand for? Some of the products I have looked at look like extenders, others look like switches. |
Just look for the extenders you don't need a switch. You would only use a switch if you had multiple computers running off one KVM (keyboard video mouse), and you switch between them.
Firewire extender for 002 RACK | [email protected] | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-19-2010 12:31 PM |
Digi 003 Factory Control Surface via firewire extender | geigerfro14 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-13-2009 02:58 PM |
firewire extender and 003 | evs | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-23-2007 04:16 AM |
Gefen Firewire Extender + Digi 002 | alexandre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-02-2004 03:10 PM |
USB Extender | uno1234 | General Discussion | 3 | 04-27-2001 07:00 AM |
