Old 10-19-2009, 10:33 AM
scottleader scottleader is offline
Default Elastic Audio changing speed of tracks on import...
I am dragging .wav files into a new pt session and even though "Enable Elastic Audio On New Tracks" is NOT selected in my prefs, each new track is activating a tick based track, computing elastic audio, and changing the speeds of the new tracks on import.
How can I disable this so when I drag a .wav into the track list it just pops it onto a new track with no processing the way its supposed to do it?
8.0 cs3
Old 10-19-2009, 02:00 PM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Elastic Audio changing speed of tracks on import...
8.0 cs3
This only happens if the wav's have metadata like rex and acid files!
Where did these wav's come from?
doesn't happen if you use import audio from file menu
Chris
Producer, Engineer,
www.ukmastering.com
Old 10-19-2009, 08:18 PM
Yeaaaa, good point. I called the engineer that sent me them and I guess they had tempo data attached to them from DP.
So weird-thanks for that explanation.
Session Changing Speed After Import Audio zsarbomba Pro Tools 10 7 01-10-2014 01:00 PM
Why is Elastic Audio changing .aif/.wav file sizes!?!?! Rufio Pro Tools 10 3 12-25-2012 09:17 PM
Can't Import Elastic Audio Tracks (Access Violation) jrwiles1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 09-28-2011 04:05 PM
Speed up both Audio and Video with Elastic Pitch? Ormond 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 03-19-2010 10:26 AM
How do I import cd tracks in order to use elastic properties? dbluprecords 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-06-2009 01:40 PM
