from 8.0 to 7.4.2
Dear Digi,
I am using a G5 DP and a ProControl. With PT 8.0 (and 8.0.1) I have the matrix problem and the fix will be in 8.0.2, but that version won't support the G5. So I guess I have to go back to 7.4.2. The last version I bought before PT 8 was 7.1. Do I have to buy 7.4.2 or will it work with my 8.0 licence on my ilok? Thanks, Niels |
Re: from 8.0 to 7.4.2
Cause that's what you need, a 7.4 iLok asset. 7.1 and 8.0 are different iLok assets. On the other hand they may fix that bug in a cs release. |
I never worked with 7.4.2. My last update before 8.0 was 7.1.
So I have to buy an 7.4 asset after I bought an 8.0 asset which I can't use because of a bug? Can I not swap my 8.0 asset for an 7.4 asset? Digi wrote that the fix for the matrix bug will be in the next non-cs update. |
On the DigiStore, there is this note in the listing for 7.4 updates:
"Note: Pro Tools 7.4 upgrade purchasers are automatically eligible to receive a free upgrade to Pro Tools 8 software." Since the 7.4 update and 8.0 update are the same price, a little wrangling with customer support or your Digi rep might get you sorted with a 7.4 license. In theory, it should be the same to Digi money-wise. |
Digi support gave me a licence untill the end of the year.
This is what he wrote: There is a known issue with the matrix from the ProControl, number 115111, our technicians are currently working on a fix for it, in the meantime, I will give you a temporary iLok license for Pro Tools HD. Does this mean Digi will have an PT8 update supporting PPC, before the end of the year? That would be cool! |
I actually have a backwards question to this! I have a PT HD 7.4.2 iLok that came with the box. Now i just did the PT HD 8 upgrade box set and no iLok, just activation card. so i activated on digi (avid) and transferred to my iLok account. But I cannot download to the PT 7.4.2 ilok, says it's in use with another account. So essentially..I have to BUY another iLok for PT 8!? I cannot use the same iLok??
you'd think after spending close to $10,000 they could make something compatible... If I'm wrong any help would be great! Thanks =) |
Customer service may be able to help you - as long as you've not downloaded the PT8 auth yet, they may be able to reverse the deposit and help you get it deposited to the same account you registered the 7.4.2 iLok under... |
But the odd thing is I never registered that to another account. I actually never registered that iLok at all. It came in the box with PT 7.4.2 with an auth on it..I never had to sync or download a license
and Digi phone tech support says they cannot help with auths or iLok issues (the automated message) |
I have been BEGGING Digi to revert my 8.0 license back to a 7.4 and they wont do it. So, digi if your "policy" has changed I will GLADLY give up all the BS i have had to deal with since my 8 "upgrade" and to go back to the smooth sailing days of 7. Please... Please... You can even keep the money!
This sounds like someone has sold you an "orphaned" ilok that is no longer registered to an account. if this is the case then any ilok auth on such an ilok are unable to be updated or upgraded, those iloks are fixed it time. Chris
