MIDI drum track to audio?
Hi all,
Trying to get a MIDI track already recorded from electronic drums - separated and recorded to individual audio tracks for mixing in PT's 10. Any help appreciated! Thanks |
Re: MIDI drum track to audio?
Which VI are you using?
There are a few ways to do it depending on which VI you have. The basic principle is to create audio tracks for each drum. Set each track's input to a Bus... For example Bus 1. Then assign your VI's output to Bus 1. Now you can record your VI's audio on the new audio track. If your VI runs "multiple mono", then you can record all tracks (On Bus 1 through 10, for example) at once. If it doesn't have multiple mono, then you'll want to mute individual MIDI tracks so that you only record one instrument at a time. I usually don't do ALL drums separately. I haven't found it to be necessary. I usually do Kick, Snare, Stereo Toms, and Stereo Cymbals. 6 tracks altogether, and I can tweak as much as I want. I hope that helps! Good luck |
Greg,
Sorry in the delayed response...lost computer to crash - just getting back up to speed. I only track right now from a electronic drum set (brain)... yeah i know outdated, but can i still replicate what you suggested above? Thanks! |
No worries... Your sound source is an external unit? Yeah, no problem...
Just mute the MIDI tracks you're not recording and record the audio from the "brain" a few instruments at a time. Have fun! |
Great thanks will give it a go!
Once you start using something like Addictive Drums or EZdrummer with your E-kit, you'll never bother with external sounds again
How do I add drum sound to a midi track? | RunningFree | Pro Tools SE and Essential (Win) | 2 | 05-10-2011 11:41 PM |
MIDI Drum Track Not Playing | bmcoonan | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-18-2009 03:23 PM |
i need to slow down the end of a midi drum track | billymc | MIDI | 3 | 05-24-2006 04:05 AM |
Utility for splitting midi drum track | DonaldR | MIDI | 0 | 08-13-2002 08:58 AM |
MIDI drum track | MrMike | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-07-2002 06:17 AM |
