MBox 3 Pro + ElevenRack: Why I don't see both?
Hello All,
I recently bought an MBox 3 Pro to use it as my main interface. Before that, I was using Eleven Rack as interface. I have both connected properly and I can chose any of them as "Playback Engine". However, I can only see the one that is selected as "Playback Engine" in the [Setup -> Hardware] menu. Is that normal? I think one should have the ability to change parameters for both interfaces without having to set them as Playback Engine first. I kinda remember I was able to see 2 interfaces in that menu when I had a Digi 003 and the Eleven Rack at the same time, but I'm not completely sure I remember correctly. This is resulting in a problem because (and maybe this is another bug) when I start ProTools with the MBox as default interface, it automatically goes to 44.1 Khz resolution. Since I have the Eleven Rack configured to take its clock from the MBox via S/PDIF, the Eleven Rack goes to 44.1 Khz too. But then, if I open a session at 96 Khz, the Eleven Rack continues to take the clock from the MBox BUT keeps its resolution at 44.1 Khz, which starts to cause a lot of clicks and pops. In order to resolve that, I have to: 1) Close my session 2) Change the MBox default resolution manually in the "Setup -> Hardware" menu to 96 Khz 3) Change the default interface to Eleven Rack in the "Setup -> Playback Engine" menu 4) Open the "Setup -> Hardware" menu again so I can see the Eleven Rack and change its clock to "internal" (so I can move the rest), then change the resolution to 96 Khz, then change the clock to "S/PDIF" again. 5) Change the default interface to MBox in the "Setup -> Playback Engine" menu 6) Reopen my session That just doesn't seem right, but the darn thing is not automatically changing the Eleven Rack resolution when its clock is set to S/PDIF and the Playback Engine interface is the MBox. Shoudn't the Eleven Rack modify its internal resolution automatically if its synched to the MBox via S/PDIF? If the answer is "no", then I think I should still be able to see both interfaces in the "Setup -> Hardware" menu, it would be a lot faster to fix the problem. Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
Re: MBox 3 Pro + ElevenRack: Why I don't see both?
A couple of issues here:
1. The new Mboxes, whenever something is hooked up via Spidf, require that they be clocked externally from whatever is hooked up to them. So you have to have the Eleven Rack be the master clock, not the other way around. I don't know why they did this, but they did. It's specifically stated in the manual. Some third party interfaces also have this requirement, such as the NI Komplete Audio 6. So that will hopefully take care of the clocking problem. 2. You should probably use the Mbox as your main interface. You can still have access to the Eleven Rack GUI Window as long as it is still hooked up by USB, even though it is not selected as the main interface. So you can still use that to change parameters, etc. |
Two interfaces would show up in LE8, I did it. But I sold my 003 before I got PT9 and from what I am told, both interfaces do not show up anymore.
You can control the Eleven Rack clock and sample rate from the Eleven Rack Control Panel in CONTROL PANEL on Windows.
Brian Windows 11 Pro | macOS 12 Pro Tools 2022 benonistudio.com Youtube Channel - benonistudio Plugin Deals @benonistudio |
And, most important yet: it PERFECTLY works that way. The only thing being an issue is having to do a ridiculous process to setup the clocking before opening a session, just because ProTools doesn't show the Eleven Rack in the Setup -> Hardware menu if it's not selected as the Playback Engine. It should show it there, it's seeing it and it's working with it. Quote:
About the control panel icon for Eleven Rack, it would be perfect if it was usable when ProTools is open. Once ProTools takes control of Eleven Rack, that control panel app shows everything grayed out. :-( Francisco
I'm having a similar problem. In my case rather than a mbox I have a tascam DM4800 with firewire card as my audio interface into PT10. But your workaround doesn't work for me because I can't see the 11 rack as an option in setup>hardware or setup>playback engine. Yet it works fine in 44.1. but when I set my mixer to a different sample rate I cannot get the 11 rack to change along with it. really frustrating.
Francisco
Even if you're using the 11R hooked up digitally to your other interface, you still need to have the 11R hooked up by USB to the computer in order to access the GUI window. Assuming you have that hooked up, the window will be in the upper left drop down menu called "window".
If its the Eleven Rack Control Panel then: It is in Control Panel on Windows and on OSX I think its in System Preferences. If its the 11R UI then nst7 has your answer above.
I managed to solve my problem by downloading the latest 11R driver 1.1.1. once that was installed I could see the 11R in the setup>playback engine and once I switched the clock source to the AES/EBU all the clicking and popping disappeared and when I changed sample rates on my mixer the 11R followed automatically.
From what I've read, you need driver 1.1.1 to work properly with mountain lion on PT 10. |
Rage against the ElevenRack! | adamqlw | Eleven Rack | 5 | 09-19-2012 10:43 PM |
Help with ElevenRack in Pro tools | JonWillford | Windows | 0 | 05-13-2012 07:16 AM |
Some over the top heaviness from the ElevenRack | adamqlw | Eleven Rack | 2 | 03-11-2012 08:44 AM |
AVID 16/16+ElevenRack | DCommand | Pro Tools TDM Systems (Mac) | 0 | 11-06-2010 11:42 PM |
ElevenRack Driver 1.0.8 (x64) | pianosound | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 07-14-2010 11:44 PM |
