Old 10-11-2015, 06:48 PM
megatracks's Avatar
megatracks megatracks is offline
Default S3LX USB playback audio not available on 2nd networked S3LX
Does only audio from physical inputs mic/line only split to 2nd station? I've double checked my set up and only physical inputs are showing up on shared S3LX. Any help is really appreciated. Thank you.
Old 10-15-2015, 12:03 AM
Sheldon Radford's Avatar
Sheldon Radford Sheldon Radford is offline
Default Re: S3LX USB playback audio not available on 2nd networked S3LX
In multi-engine setups the I/O from the Stage 16s is shared between the engines. USB audio, the engine I/O and console I/O are local to the engine they're connected to.
Sheldon
Old 10-15-2015, 03:23 AM
megatracks's Avatar
Thanks for the reply. How then would I get USB audio to the second engine? USB audio is being used as part of a live event.
Old 10-15-2015, 06:11 AM
Valentyn Valentyn is offline
You can do that via Stage loop. Output USB from master system to a shared Stage, then connect it back to stage's analog input. You'll then have it as a shared stage input.
Old 10-15-2015, 06:29 AM
megatracks's Avatar
Thank you
Digital Pops and Clicks Recording Protools S3LX Venue adamfarrell VENUE Live Sound Systems 1 11-05-2014 02:28 PM
Protools LE on a networked PC Rob Enders 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-28-2004 07:06 PM
Audio File transfer to Networked Hard Drive dharpo32 Pro Tools TDM Systems (Mac) 1 03-09-2004 06:02 PM
Anyone networked their PCs? greenroom 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 17 07-30-2002 05:16 AM
uses for networked Macs...... Doug Shugarts Pro Tools TDM Systems (Mac) 4 02-20-2000 11:05 PM
