Old 01-11-2019, 11:18 AM
jphaudio jphaudio is offline
Default Minor Issue After Upgrade
Upgraded to 12.3 today and my artist mix surface vertical zoom in/out buttons are not responding. The horizontal zoom in/out is working. Not sure if this is symptom of another issue.
A reboot of Eucon fixed my touch screen, as it was scrolling from page one to page 150, and missing everything in between. The Setting showed each page. After I restarted Eucon, the page scroll works fine now.
Everything else seems ok so far...
Was wondering if anyone had this same/similar issue ref the vertical zoom not working.
I saw a post that was triaging a different issue, but maybe I can try this..: (Remove Eucon from startup then reboot, after reboot add back the Eucon to startup)
Thank you...
Old 01-11-2019, 12:22 PM
Default Re: Minor Issue After Upgrade
Working on this further...I see my 'shift' key is locked, so when I press it ponce it activates for both my mix and control surfaces. Still not able to get my vertical zoom working from the control surface.
I also noticed that when the shift button is active/locked, thats when I scroll from page one to page 150, on my touch screen. When I unlock it, I can scroll numerically.
Getting confused now.
Any help or suggestions are very helpful, Thank you
Old 01-11-2019, 12:27 PM
I found that setting that fixed the problem. The upgrade is good, I just wish Avid created an updated in-depth manual with all the new features and customizations. Too much experimenting... but great product though.
Minor Track List Issue dmacintyre 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-07-2009 06:25 AM
Having a minor issue with XP and RTAS Mindcrime 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-21-2006 12:32 PM
Minor Issue, Probably a simple fix Eless 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 08-31-2005 05:38 PM
minor 6.4 bug schiffdigital Pro Tools TDM Systems (Mac) 2 04-29-2004 06:00 PM
