#41
Re: Will elastic audio ever get fixed?
Not bad James! Interesting workflow. Thanks for doing this. Just some anomalies (especially on the downbeat of bar 2), but better than x-form for sure. I just wish it could be as easy and quick in Pro Tools as it is in Logic.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs |
#42
OT- have you had any issues with the Red 8Pre 2.3.3 (or now 2.3.2) firmware/driver and TB functionality with you hacks? Mine isn't working (5960x X99 A-ii with ThunderboltEX3), but does still work with real macs. Last edited by RyanC; 03-09-2018 at 07:41 AM. |
#43
Is it using TB3 on real macs?
TB3 is only on Laptops from what I remember, all the trash cans I believe had TB2 I have the X99 A ii Deluxe (or something like that) I know that in the BIOS you have to configure the PCIE cards to allow the TB slot a lane.... The mobo manual hopefully makes it clearer than I stated it.
#44
While i can access the Red 8Pre via Focusrite Control, actually passing audio via TB on the hack is another matter. I have not been able to get it to work with any app, not just Pro Tools. I think I'll have to accelerate my plan of getting an HD Native card. Do you know why Focusrite reverted to 2.3.2? I could not get the Red 8Pre to work with my Macbook until 2.3.3 so it seems odd to me that they pulled it.
#45
I remember reading that while you can choose X-Form as the default TC/E Plug-in algorithm, that does not mean that's the algorithm that gets used for EA in quantizing audio, for example. EA uses it's own algorithm. You can test this by switching the default TC/E Plug-in to various other choices such as Pitch 'n Time, Waves Soundshifter, Z-plane, etc., and it doesn't produce any difference in the results. So X-Form, which is excellent and is based on Izotope's Radius, works great in Audiosuite mode and with the TC/E tool, but doesn't come into play with EA. If it were to be used here, I'd bet PT would be ahead of Logic in this dept.
#46
On my systems the Red 8pres were working great on TB (as was a dock with USB HDMI etc) until 2.3.3. Focusrite gave me the files and procedure to wipe the firmware and reupdate, but it kindof bricked my units. 2.3.3 would not re-rewrite the firmware. Then when I went back to 2.1.8, it works again, but the screens on the front of the 8pre are stuck. At this point focusrite sent me 2 replacements, but neither of them will work with the hacks either. I have a nMP and am switching to that for now...I'm moving into a bigger space soon with more people working and moving forward I might just switch back to real macs (fingers crossed the next round of mac pros is more of a *normal* computer...) If you erase your firmware (I can share the FCtool if you want it) and reset to 2.1.8 it will *work* but only a 44.1 and the screens on the unit will be stuck at the bootup screen. Updating back to 2.3.2 or higher makes it only work with real macs again, and yes it won't get any audio from any app. The downside to HDN is that without TB you will not be able to connect the ipad app or control anything from the FC app, if you need those functions. |
#47
#48
Ea has multiple algorithms.. it defaults to an average polyphonic one.. i wonder if that's what you are using hence bad results.
- Apple Mac Studio M2 Ultra/64gb/UA Apollo x 3+Adat x 3/UAD Satellite x 3/OS 14.41/PT 2024.3/Nuendo 13/LogicX |
#49
I just did it.. imported piano original file into 100 tempo project..
enabled elastic, chose x form as elastic algo. quantized to 1/8th. zero of the artefacts in your EA file. None of them at all. As i thought. Ok, edit, right at the end, and only right at the end when the piano gets quiet, there are a couple of warbles.. This is simply because Pro tools has put too many transient markers in automatically and is quantising them all to grid, all tiny little snippets of the audio when they should be one note.. I will delete the rogue transients and this will be flawless. I will do it later though as it's Sunday and I have a moomba to go to. :)
#50
Great! Let's hear it!
Why Elastic Audio are not installed in Pro Tools 12? Elastic Audio not working :( | ChiLLoUt | Pro Tools 12 | 9 | 01-20-2018 12:56 PM |
Elastic Audio: X-Form vs. Disable Elastic Audio | sharchik | macOS | 1 | 09-22-2014 01:49 AM |
Render elastic audio alert when not using elastic audio! weird! | jjboogie | macOS | 7 | 03-26-2012 09:01 PM |
committing elastic audio in 7.4 is it fixed yet | 2fly | Pro Tools TDM Systems (Mac) | 9 | 01-15-2008 05:08 PM |
Elastic AUDIO, or Elastic TIME? | SoundWrangler | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 11-13-2007 11:21 PM |
