BUG: region-naming in 7.3.1cs1
I think the region-naming is buggy in 7.3.1. Try this: - double-click on a "whole file" on a track using the multi-tool. -chose "rename region and sound file" and enter a name already used in the session. PT will then say "region-name" already in use and take you back to the naming window. -now chose "rename region" and enter the name again (or any other name). PT will again say that "the file-name is in use already". -Now cancel the operation. -double-click the region again and now chose "rename region" first and enter a name. PT will again say "can not rename. name is used". PT will only allow you to name the region after making some edits. This isn´t like it should be or did I get something wrong? Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
Re: BUG: region-naming in 7.3.1cs1
Frank-
this bug has been around since time began (at least since PT 2.0) The whole file region is always the same as the file name. I do not know if a fix is possible, but perhaps someone does know... charles maynes
charles maynes sound design and recording for film and media 818 618 0580 Member IATSE Local 700, MPSE, ATAS, NRA & USMCHC. |
Naming region by default? | PPM6 | Pro Tools 9 | 1 | 01-25-2012 05:27 AM |
Separating/naming region issue | John calvert | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-15-2010 06:04 AM |
Region Naming | mushoo | Tips & Tricks | 3 | 04-19-2008 05:57 PM |
Loop record and region naming | kalab | Pro Tools TDM Systems (Mac) | 0 | 09-20-2007 09:49 PM |
Region naming has changed | ripple FX | Pro Tools TDM Systems (Mac) | 0 | 04-05-2007 04:36 PM |
