Old 07-28-2016, 06:31 PM
royfan royfan is offline
Default SIMPLY need to just delete pro tools projets from my Cloud Dashboard..
really simple, just need to delete projects from my dasboard..
but can't find the proper menu on the avid site once I"m logged in..
Old 07-28-2016, 07:12 PM
Southsidemusic's Avatar
Southsidemusic Southsidemusic is online now
Default Re: SIMPLY need to just delete pro tools projets from my Cloud Dashboard..
Are you talking about PT|First here or the cloud collab in PT12?
I will try to get a quick answer as soon as I know what PT you are using
Best Regards
Christopher
South Side Music Group
WEBHOME
Old 07-28-2016, 10:43 PM
Hey thanks for your quick message!
In the time being, I figured out I can just delete the project from the PT First dialog that shows you your 3 projects (it has a limit of 3). I thought I had to delete it from the avid cloud. I guess deleting locally deletes from the cloud as well.
I did have another question though.
One of the reasons I'm trying PT (from Logic), is that I'm under the impression it runs with less bugs. Though I know bugs with DAWS are also unique to environment.
I'm Far from from running it on a "pro rig". And it's crashed quite a bit today already (my first day). I'm on a laptop with 4 GB RAM and quite a bit of hard disk space I believe so I realize those are the best specs, but it can be crashing this much just from the small RAM?
I'm afraid that if I invest the 700 or whatever for a license I'll still have problems and Avids support will be too expensive.
Is the deal basically that PT runs pretty much real solid stable only on heavy duty serious rigs?
Pro Tools First - Dashboard is empty right now Defier Pro Tools | First Discussion 1 03-18-2016 04:52 PM
Disable cloud in pro tools 12 Kit67 Pro Tools 12 2 10-07-2015 03:09 AM
You simply HAVE to see this !!!!!! (iPhone - Pro Tools) gtrplyr1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 12-14-2007 12:40 PM
SDII and PT Projets II Juampa Digidesign Hardware & Software 1 11-23-1998 08:28 AM
