Spdf Input to usb Mac
I'm looking to get a new Imac just to Mix and burn to.
I'll be running Peak, but I need to get into the Mac digitally. Also I want to keep it in OSX. Any cheap suggestions. I checked out the Edirol but it's 16 bit only and plays back at 48kHz only. Help!!!!
Pro Tools Tutorials: Mixing Heavy Rock & Metal Pro Tools 11 - Tips and Tricks Delay Explained Tracking Rock - Drums Mixing Rock Music Production with Pro Tools Pro Tools Tips and Tricks Vol. 2 Pro Tools Tips and Tricks Vol. 3 Elastic Audio in Action |
Re: Spdf Input to usb Mac
I used to be able to bounce through ethernet to my G3 but after my 5.1.3 upgrade I couldn't anymore. Is that what you are needing?
How would you bounce thru Ethernet?
Sounds like from your post that you are looking for a USB interface that supports higher sample rates like 96k.
Your choices are limited, and you may not consider this cheap. The only interface I can think of that hooks up via USB and has high sample rates is the Apogee Mini Me. It supports sample rates up to 96k, and has a lot of nice features. But it goes for around $1395. But you could use it as a record path for remotes and other things. You have more choices if you can deal with a 48k limit. Even the Mbox will do this via spdif. Something a little more high quality (than Mbox) would be the USBpre. See it at www.usbpre.com It's about half the price of the Apogee.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor |
I don't need the preamps and I don't really need 96kHz either.
The edirol cable doesn't do 44.1kHz (only 48) I would prefer 24 bit though.
alias hard drive of G3 on desktop of G4 sellect alias in bounce dialog bounce as usual....ta da [img]images/icons/smile.gif[/img] but since I upgraded to 5.1.1 and 5.1.3 I get "not valid hard drive" [img]images/icons/frown.gif[/img] I'm not sure what changed and I really was doing this for at least a year. |
M-Box?
Not X yet, but in nearest future ;-) Przemek.
http://imaginatlh.com/91709 |
Have you seriously considered a late generation Windows PC (with USB 2.0) ?
For example Wavelab 4 is a real killer for CD editing/mastering, and there is plenty of high quality hardware at reasonable prices. Considering that setting up a PC-Mac network is getting easier everyday, and you could even exchange files later on. Just a thought to meditate [img]images/icons/cool.gif[/img] |
I actually considered going to the PC world, as I heard great things about WaveLab but I don't think I'm ready for a new operating system. OSX is bad enuff.
As far as the mBox I do own one (Hate it) but Pro Tools still makes you use those Split stereo files which makes it a bitch for cataloging stereo files. (I'm too lazy to convert) As far as that Edirol cable, it lets you record at 44.1 but playback at 48 only. Does that make sense to anyone.
If there is an ASIO driver for the MBox you can use it to record stereo interleaved files directly into PEAK. I used to do it with Digi001, and all of the 001's inputs as well as clock sources were available from within PEAK.
I'm not sure if there is an ASIO driver for MBox though. Good luck, Jeff D. |
mBox 2 SPDF out to AC3 or DTS? | Farmer Dave | Pro Tools TDM Systems (Mac) | 7 | 02-06-2010 01:59 AM |
Using SPDF of Motif ES to 002r | dubaifox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 02-26-2006 08:40 PM |
help with using external spdf FX unit! | stephen duffy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-19-2004 03:09 PM |
NO SPDF OUTworks TO DA-30 !!!! DIGI 002 !!!! | arigar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 11-08-2003 11:41 AM |
external fx with spdf | jb hoste | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 20 | 08-08-2002 04:31 PM |
