Old 07-03-2013, 08:24 AM
roberts roberts is offline
Default Please Fix the midi Timing
midi timing in PT 11 is terrible floats so bad with different VI's you even get different MIDI timing problems. If it was consistent it would be OK but it floats so bad it's totally unusable.
I heard it in 5 bars on the first VI I tried - does someone beta test this stuff?
Old 07-03-2013, 12:28 PM
daish daish is offline
Default Re: Please Fix the midi Timing
Please tell me this (if true?) will be fixed ASAP, I'm still using protools 8 with an HD3accel, on a G5, fighting against bad midi everytime I want to use VIs. I'm waiting to see which upgrade path is the smartest for futur (HDX, HDN, new macpro, PC...), I was sure such a jump from my actual setup would at least give me a useable midi (you know like with an Atari ST running notator !!) just what you play is what´s recorded ! IS IT SO HARD ?
Is there still midi problems in PT9 or 10 ?
Old 07-03-2013, 03:17 PM
Touchwood Studios Touchwood Studios is offline
Superior and Slate SSD (with VEP5) both float the crazy thing is that SSD with VEP is tighter
both still swim
Old 07-03-2013, 03:22 PM
jasonthurley's Avatar
jasonthurley jasonthurley is offline
Is this with Delay Compensation turned on or off?
-Systems Engineer, Systems and Sound Designer, Recording and Mixing Engineer
Old 07-03-2013, 04:09 PM
Sardi Sardi is offline
Is this confirmed?
So we finally get a release where we can actually use VI's properly and it suffers from MIDI timing issues?
Oh dear....
Old 07-04-2013, 08:08 AM
WernerF WernerF is offline
It's hard to see this be so totally ignored for so long a time. It is ridiculous when you consider that it is better in other DAW's. If the makers of those products can make midi more accurate why then can't the Avid engineer's apply some degree of diligence to a VERY important issue.
Old 07-04-2013, 08:35 AM
boomsounddesign's Avatar
boomsounddesign boomsounddesign is offline
Odd I haven't seen any issues so far.
My Gear
Mac Pro (mid 2011) - 2x 2.8GHz Quad-Core Xeon, 16GB RAM, ProTools HD Native, UAD Quad.
HD IO 16x16 + Lynx Aurora 16
Solid State Logic Matrix
B&W 800 series + Yamaha HSM80s
Mojave Audio, Royer, Neumann, Audix, Yamaha, AKG and Shure mics. Focusrite ISA828, SSL Alpha VHD, UA LA610-mkii, M-Audio OctoPre, Avid Eleven Rack
Canare and Mogami cabling.
http://www.boomsounddesign.com
Old 07-04-2013, 10:19 AM
cryophonik's Avatar
cryophonik cryophonik is offline
I haven't noticed it either.
Old 07-04-2013, 01:05 PM
Rectifried Rectifried is offline
me Neither... Superior is ported to 64 aax?
Hal Cragin On the DUC Since The Year 2000 AD
Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2]
Old 07-04-2013, 02:09 PM
nedorama nedorama is offline
haven't seen any issues at all running 8 channels of MIDI out to hardware synths, plus tons of virtual instruments, etc. at 128 setting. If anything, MIDI timing is greatly improved given that I can now run 128 with tons of the AIR 11 VIs (boom, structure, Xpand, DB33, Grand Piano) and plugins.
Of course, without the OP's and others settings and system information, it's hard to understand if there's really a problem, but I'm not seeing it. While the OP may have specifics like which VI's he used, otherwise this looks like flamebait.
In general, if you're noticing a problem, give specifics - what system, what VI, etc. Otherwise, sweeping general statements like this are not helpful.
Regards,
Ned
Monkey Boy Studios
2019 16" MBP, 32GB, 1TB SSD; OSX 10.15.7; 4TB USB-C G-Tech External
Summit Audio 2BA-221, TLA-50 -->Focusrite 18i20 3rd Gen, Eleven Rack, Pro Tools 2021.3
Plugins, Virtual Instruments, and real ones
Midi timing in PT =>6.0 Zeus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-26-2003 03:36 AM
MIDI Timing on PT LE DooDooDoo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 25 09-02-2002 10:54 AM
001 midi timing/midi clock/MTC...any probs? Adam Inglis 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-01-2001 09:33 AM
MIDI to CV midi timing ??(kenton) any good ? sandman MIDI 1 04-21-2001 06:36 AM
Midi timing on 001 who 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 11-11-2000 08:50 PM
