LM100 oddity
hey folks-
my first time w/ the LM100 and i'm noticing something odd. assuming i've got it set up correctly (i believe i do), the unit is having a hard time "listening" to a male VO in my spot. i'm doing a 5.1 :30 TV spot and for the moment i'm feeding a mult of the center channel into the LM100. i've sent it in via AES/EBU pair using a Canare converter and i've also tried the analog input into the unit. in either case, the female VO option (we haven't picked the final VO yet) reads almost immediately on the unit, but the male VO almost never reads. i have the unit set for "Infinite" mode and "dialog intelligence" on (this is the spec i was given to mix to). all i can figure is the male VO is a very deep voice and the unit is not reading it as dialog. the "no dialog" message is displayed and the DialNorm reading flashes constantly. i can get it to "read" the male VO every once in a while but this is scaring me. anyone have any insight on this? i'm prepared for the possibility i have it set up wrong, but since it reads the female VO well, i think it's correctly set up. i'd be willing to post an AIFF of the center channel w/ either or both VOs if any kind soul wants to see if i'm on crack. thanks so much for the help/opinions, marty. |
Re: LM100 oddity
The infinite mode is there to read levels over a long period of time. For something short try the "short" mode. Reset the unit before you play back and hold it in pause until you start playing. You should be able to get a good reading that way.
Philip Perkins |
Re: LM100 oddity
I don't want to sound stupid, but are you actually seeing db levels at all on the meter? Are you actually set to look at the correct channel?
cheers geo
georgia hilton CAS MPSE MPE Hilton Media Management Film Doctors http://www.filmdoctors.com Me... http://georgiahilton.webs.com/ Stage 32 http://www.stage32.com/profile/6569/georgia-hilton My Production Company http://www.hiltonmm.com CREDITS (partial) http://www.imdb.com/name/nm0385255/resume MEMBER: IATSE LOCAL 700 |
Re: LM100 oddity
Georgia-
i'm the only one who has to worry about sounding stupid i assure you. yes, i'm reading levels, etc. on the meter. and yes, i'm sure it's "hearing" the correct channel. as i said, it reads the female VO very well..just something about the male's voice quality isn't reading well on the meter? dunno. i'll keep messing with it to see what's what. thanks, marty |
Re: LM100 oddity
thats an odd one.. I've never run into this type of problem. Can you Eq the Dialogue a touch to make it read better, then remove it for laybacks... Obviously the only issue with this is the level change, if any, when Eq'ing. I guess you could check the meters when you do the Eq and adjust so it's the same gain level...then run the Lm100 for dialogue norm level. Then lose the changes for printmaster.... ( ugh )
cheers geo
A VI Oddity with PT | DonaldM | Virtual Instruments | 4 | 12-04-2009 10:22 AM |
Structure oddity | DonaldM | Virtual Instruments | 12 | 11-13-2009 06:05 AM |
Fw400 oddity | Jedi Patel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-29-2008 11:30 AM |
No program changes with Oddity? | Gothboy | Virtual Instruments | 0 | 12-14-2007 03:31 PM |
Timestamp oddity or bug | Chris Erlon | Pro Tools TDM Systems (Mac) | 1 | 10-25-2006 11:32 AM |
