Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
#21
![]() Quote:
Daniel HDX - PT12.5.1 - HD I/O 16x8x8 Win10-Pro (v1709)- 6 Core i7-6850k - ASUS X99 Deluxe ii D-Command Main Unit - 'Ole Blue Why hasn't track folders been implemented yet? - (big : P.O.S. , apart) |
#22
![]() Quote:
I would definitely rather have a second hand D-command than an S3/Dock but grey ones are VERY thin on the ground in the UK. (I waited a year and only saw one ES for sale which was WAY overpriced. A few blue ones were available but they looked pretty shot.) The S6 does have plug-in mapping.... sort of. You can now map plug-in parameters to faders and it works quite well. It's no substitute for full plug-in mapping though so I'd say that was a fair criticism. Also, you STILL can't instantiate sends and plug-ins on the S6 which is pretty poor IMO. That said there's a LOT of stuff you can't do on the D-Command and a lot of stuff you can do a lot faster and more productively on the S6. There are also some VERY cool features in the works for the S6 ![]() If I had found a D-Command ES for a $6.5k I would have jumped on it though!
![]() ![]() UK Avid HDX1, PT12 HD, HD I/O 16x16, Avid S6 M10 24-5, 2013 12 Core Mac Pro. Robby The Robot meter bridge ornament. |
#23
So this all reinforces my decision that when and if a PT update "breaks" the D-Command I will freeze my system there and stop upgrading. With music recording budgets as low as they are it makes no business sense for me to spend the kinda bread required to enter the S6 pond, and the S3/Dock solution, while pretty slick and compact, would result in the loss of a lot of functionality I use daily on my D-Command.
Time to consider stockpiling spare parts.
Will Russell Grammy winning engineer Electric Wilburland Studio www.wilburland.com 12 core 3.06Ghz MacPro, OS 10.12.6, PT12.8.3, HDX, D-Command Retina 5k iMac OS 10.12.6, PT12.8.3, MBox3 Retina MacBook Pro OS 10.13, PT12.8.3 |
#24
![]() Quote:
+1 As more people explains the new workflows for s6 facility's I am more afraid to let go my D command. |
#25
Ditto here,
I picked up a second 24 fader blue DCommand as a plan B. They are going for around 4k on average which is a steal!
Brian Power, CAS www.thehideoutstudios.com 2 Mixing stages in Nova Scotia! Home to the Trailer Park Boys, 22 Minutes and Mr D as well as many more. Need proper ADR in Nova Scotia? I'm the call to make. |
#26
![]() Quote:
Where else can parts be sourced? I would take power supplies and faders would be needed in time. |
#27
![]() Quote:
Supposedly this is the same thing. https://power.sager.com/snp-z10b-397...gn=power-brand |
#28
These are the 3 PSUs inside the D-Command.
SNP-Z107 12vDC 11A(https://power.sager.com/snp-z107-3979622.html) SNP-9544-15v(https://power.sager.com/snp-9544-3985292.html) SNP-Z10B-3-3v-30A(https://power.sager.com/snp-z10b-3979628.html) The main 8ch unit has all 3 whereas the fader exp. unit has Z107 and Z10B. I have replaced Z10B on my fader exp. unit to resolve the "flashing LEDs" problem in the past. And I have recently replaced the Z107 on my main unit because the unit didn't power up. From my understanding, the PSUs are made in Taiwan. Hope the parts # would help people who are in need of PSUs replacement. Best, Simon Li at nOiz |
#29
Faders are usually off the shelf alps units and you'd just need to solder them to the stock fly leads.
Even power supplies could be sorted out with off the shelf alternatives of the correct voltage and current if originals are no longer available, I've done this with Pro Controls and Fader packs (sourced an alternative suitable supply redrilled the chassis to mount it and moded the cable harness to suit). I'm sure pots could be sourced too, my only concern would be buttons & switches. This might be beyond the kind of work some people want to tackle but it's all possible none the less.
www.Pro-Tools-PC.com We Know Our Stuff With Pro Tools On Windows & Build Machines That "Just Work" Avid HD Native PCIe 2x 192io's, 96i,96io Pro Tools HD 10/11/12 Pro Control & Fader Pack Artist Transport & iPad Control App facebook.com/ProToolsPc Join the Facebook Pro Tools Windows User Group Twitter: @ProToolsPC |
#30
Thanks Simon!! I copied your post into a text doc for (hopefully not needed) future reference.
Command 8 Fader Replacement | jazzer61 | ProControl, Control|24, Command|8 | 6 | 01-14-2013 07:44 PM |
When will there be a 003 or Command 8 replacement? | De93 | Pro Tools 10 | 5 | 11-07-2011 09:56 AM |
Replacement knob for Command 8?? | Livin' Proof | ProControl, Control|24, Command|8 | 0 | 07-15-2010 09:57 AM |
Command|8 Potentiometer Replacement | Siegfried Meier | ProControl, Control|24, Command|8 | 0 | 01-17-2009 02:23 PM |
Total Loss of Command 8 Command/Modifiers | John Pisciotta | ProControl, Control|24, Command|8 | 1 | 05-13-2005 10:30 AM |
