Old 09-24-2005, 12:16 PM
popsnd popsnd is offline
Default 192 digital/analog ?
Currently we have 192 Digital interfaces but we have a need from time to time for analog I/O. Can a 192 Digital accept the analog expansion cards?
or would we have to get a 192(non digital) and add two digital expansion cards to it to achieve the same as a 192 Digital with option of using 8 analog?
Old 09-24-2005, 12:23 PM
Dutchmuzik Dutchmuzik is offline
Default Re: 192 digital/analog ?
Option 2
Old 09-24-2005, 01:23 PM
Thanks Dutch
Old 09-24-2005, 02:11 PM
Actually you can only add 1 I/O card per 192, It comes with 1 AES/EBU I/O so add another in the empty slot, to get the same I/O as a Digital 192. You will also have 8 Analog I/O with the 2 other cards that are stock as well.
Old 09-26-2005, 12:24 AM
Matt_G Matt_G is offline
Of course there is another option that will probably be less hassle, sound better & maybe about the same price. Purchase a good quality outboard A/D converter. Depending on how many A/D's you need to use simultaneously. If you only need 2 channels of A/D then you could buy a really good set from Benchmark or Mytek. If you need 8 then maybe some cheaper ones like the Apogeee AD8000 etc. Any of these would sound comparable or more likely better then Digidesigns HD converters anyway.
This is why I bought the Digital 192 I/O instead of the standard 192.
Mastering Engineer
www.matthewgraymastering.com
Brisbane Australia
Old 09-26-2005, 01:51 PM
Yeppers...a 192 with one additional digital card.
I should've just read the 192 guide when I wasn't so sleepy. Makes more sense now that me head is clear.
Matt_G...I understand what you're gettin at however in our case using a outboard converter would create more problems than not.
Anyways...a sincere thanks for your assistance.
Possible using a Digital 192 I/O and an Analog 96 I/O together? c-arts Pro Tools TDM Systems (Mac) 3 05-01-2009 11:02 AM
Analog against Digital, what to do??? Moshik Pro Tools TDM Systems (Mac) 25 06-16-2003 07:04 PM
EQ - digital vs analog davidp158 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-23-2001 09:43 AM
analog to digital to analog major_thom Tips & Tricks 5 09-19-2001 04:02 AM
Analog or Digital Jason from MaggieJack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 16 03-27-2001 03:08 PM
