Old 04-24-2004, 01:23 PM
E-an E-an is offline
Default Protools duplicates audio file on opening sessions
Hi there,
Im having a problem whereby upon opening sessions, ProTools (6.2) duplicates all the files in the session quickly filling up my hard drives. Its basically appending .1 to the end of all the files.
We're running a d24 core system (w 2x dsp cards), on a G4 1.25Ghz, 1Gb Ram, 120Gb Ext Lacie FW drive, with OSX 10.2.
If anyone has any suggestions I'd be most grateful.
Thanks,
Iain
Todays posting was brought to you by the letter e
Old 04-25-2004, 01:46 PM
Giles Reaves Giles Reaves is offline
Default Re: Protools duplicates audio file on opening sess
Sounds like an "enforce PC/Mac Compatibility" issue.
Are you seeing this dialog when you try to open the file: "Please choose a folder for the converted audio files"?
I can create this situation on my Mac by creating a file with "enforce PC/Mac Compatibility" selected, and then recording some audio (after creating an audio track), and closing then re-opening the same file.
The way I got around it was to create a new session in the format I desired (checking the audio file format of the files in your audio folder) and importing the tracks (and MIDI tempo track if used) and checking "refer to source media (where possible)".
Hope this helps...
Giles Reaves
Somewhere Between Tennessee & Utah...
"Import Session Data" Audio File Duplicates acstctws Pro Tools 10 1 03-01-2013 03:06 PM
Pro tools making audio file duplicates kieranguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2010 04:01 PM
Protools crashes on opening sessions Etienne_C Pro Tools TDM Systems (Mac) 2 07-29-2010 06:31 AM
Problem opening Mac Protools HD sessions on Win PTLE csholtmeier 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-23-2007 09:08 PM
everytime I open a pt template file it duplicates tommy gunn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-07-2006 08:19 PM
