mixing templates
Hello. I'm posting a copy of a question I asked in the PT free section, because my question deals with both the free and TDM versions of PT 5.01. Also because I presume the PT personnel does not read the PT Free section...
-------------------------------------------------- Hello there, I'd like to know if there's a way to use mixing templates on PT 5.01. Not recording templates as documented in the manual and elsewhere, but mixer setups to be used for mixing existing sessions. Here's the situation: We have PT 5.01 running a PTIII system at the studio where I work. I have PT 5.01Free at home. I recently recorded an 8-track project at the studio. Every take got recorded in a different session made from a minimal template containing panning, one buss send for FX, FX return with no plugin assigned. It did not contain any channel plug-ins. I'm now in the process of premixing this project at home (using PT free), and have determined what FX I want to use, and what plug-ins I need for each channel. The problem is that for every take of every song I want to mix I have to reassign all my channel plug-ins and settigns! I wish there was a way to use a preset mixer template containing my mixdown setup that I could paste in place after I opened a session... thanks, Pierre |
Re: mixing templates
I have a suggestion only,
1. write down which plugins you use for each channel 2. try to save your plugin settings at home and save them to a disk. (not sure if you can with protools free) 3. import the plugin setting at the studio. this would make your life easier, i'm in a similar situation working at someones home studio with protools 5.3, we just recorded drums for 12 songs and it is a pain to assign the plugins manually to each song over and over again just for rough tracking mixes. in newer versions of protools you can simply import specific session data (like just you inserts and sends) to any session from any session, its great. good luck |
Free Mixing & Mastering Templates | jadown | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 02-19-2011 07:35 PM |
mixing templates | P.O. | Digidesign Hardware & Software | 0 | 02-02-2007 10:49 AM |
templates | bryan stelten | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-17-2005 06:45 AM |
Using Templates in PT LE | yavuzj | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 03-02-2005 09:09 AM |
Where I could d/l some PT5.01 templates? | smcoptyltd | Tips & Tricks | 0 | 10-13-2000 05:15 PM |
