Automatic Send Setup Commands?
Hello All,
Apologies if this had been covered? Just curious whether it's possible to setup a shortcut command to create a send on a new track? Looking to intergrate headphone mixes into PT and route them out of my Interface to a headphone amp. Thanks for any help! Kieran |
Re: Automatic Send Setup Commands?
Welcome to these forums, Kieran.
There's no key command for that. I recommend that you create a Pro Tools template with a setup that you like, and then use Import session data to import tracks and settings (no audio) into new sessions.
Just in case you weren't aware:
Pressing option/alt when you create a send will create the same send on all tracks. Alt/option + shift will create the send on all selected tracks. Also works with creating inserts, selecting outputs and inputs and so on. |
Headphone cue send setup in Pro Tools... thoughts? | keevhren | Pro Tools TDM Systems (Mac) | 1 | 05-28-2011 04:36 PM |
send input to several aux send simultaneously in D-show?? | nirels | VENUE Live Sound Systems | 5 | 05-07-2009 06:07 AM |
copy a send (w/send level intact) from 1 to 30 audio tracks? | MixerGuy | Pro Tools TDM Systems (Mac) | 3 | 12-30-2007 03:20 PM |
Newbie Question: How do you setup SEND effects??? | TBF Entertainment | Pro Tools M-Powered (Win) | 1 | 03-21-2006 07:12 AM |
how to get "Send Program Changes" pop up menu on OMS setup? | c-post | MIDI | 1 | 06-01-2001 12:11 AM |
