Host processors...again
I'm trying to wrap my head around settings on my system. In my little project studio I'm using PT 10.3.9 with an HP ProBook 4540s i7-3612QM 2.10 GHz 8 gig RAM 64-bit Win 7. Under Playback Engine my drop down for host processors shows 8. I'm seeing discussion that a rule of thumb is to use 1 less than total, but I've also seen reference that more than 4 showing may be deceiving. So should I exercise my "rule of thumb" here with 3 or 7? I fully understand not one size fits all, but if the answer is definitive to not acknowledge processors 5-8 I'd appreciate the guidance. Thanks.
Re: Host processors...again
"What is best" is still debatable. When I was on 10, I turned off Hyperthreading in the bios, and ran 3 processors in playback engine. This worked well here. Others have claimed better stability with other settings. So... Experiment a little.
I use 6 processors out of 8 at 99% of CPU if this helps you
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com Last edited by amagras; 05-04-2015 at 07:15 AM. Reason: Added details |
Hi
Im still using a Dual Core system and for some process i use 2 cores and for others 1... yess 1... with excellent results ..
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Regardless of the advice on other systems, you really need to try the various configs as TOM mentioned. What works for one computer might be all wrong for the next one(and I can see no rhyme or reason). After reading about other folks using 1 less core(than all available), different % settings and Hyperthreading off or on, I tried all possible settings and found what delivered the best performance for me was NOT always the same as what others recommend
I tested with a large session and took note of the cpu meter(at the 64 buffer, just to push things) and whether the session would roll, uninterrupted, and took some notes(yep, with that old analog system of pencil and paper).
Host processors setting! | paulwilks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-24-2011 01:38 PM |
Host processors vs. CPU vs. CPU (RTAS) | Leon550 | Pro Tools M-Powered (Mac) | 4 | 03-03-2011 05:57 PM |
Host Processors | abre | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 09-16-2010 12:36 PM |
Host Processors stuck at 1 | ChuckD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 07-03-2010 12:27 PM |
RTAS processors now Host | 77pro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 05-16-2010 10:20 PM |
