Mixer internal latency problem
I've just updated from PT 9 to 12.5.2 (forced by the theft of my old laptop) so apologies if this issue has been raised for earlier updates, but I'm now having trouble with the internal latency of the mixer. I use a lot of dub-style echoes, and like to create a feedback loop by sending the aux channel containing the delay plugin back to itself, instead of using the internal feedback in the plugin. This way I can put EQ and dynamics in the feedback loop and create various interesting effects with automation. This used to work fine in PT 9, and even with a varying tempo I could use a tempo-synced delay to keep the echoes in time. However in PT 12, there seems to be a large latency in the aux send bus or aux channel, around 1000 samples, which makes the echoes go out of time. Delay Compensation doesn't help either way, nor does changing the hardware buffer, and I can't find any other relevant settings to change. Any suggestions on how to minimise this latency? Or failing that, can anyone recommend a delay plugin with built-in EQ and dynamics?
Re: Mixer internal latency problem
Welcome to the community.
Did I understand you correctly here; you're having a signal coming in at IN buss and going out to OUT buss, and you're also having a send on that aux channel to IN buss? I would guess the latency should be the sum of plugin processing plus one sample (due to the deterministic nature of the mixer). If this is not the case, please contact support and explain why you think ADC is not working on your system.
Delay compensation is not going to be able to help when you are feeding back latency in an infinite loop. Last edited by Darryl Ramm; 08-15-2016 at 09:00 AM. |
What about turning off ADC for the channel you've got the effect on (ctrl-command click the ADC amount)? Would that help?
http://www.richbreen.com ---------------------------------------- Mac Studio / Ventura, PT 2023.12.HDX, Avid HD I/Os and Metric Halo ULN8, 3xS1/Dock Also running a Mac Studio Ultra / Ventura / HDX / MTRX / S6 |
Unlikely. The latency will be very real and still there.
Thanks for your replies, all. As Daryl says, it seems to be an internal buffer which causes 1024 samples of latency. I'll contact support and see if they have anything to say about it but I'm not getting my hopes up.
How to deal with Latency from Surround Mixer - Stereo Mixer. | Spyderrp7 | Pro Tools TDM Systems (Mac) | 9 | 11-02-2012 03:41 PM |
Improved internal mixer | eledu | Pro Tools 10 | 5 | 11-04-2011 05:15 PM |
Pro Tools internal Mixer | kmshroom | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 09-03-2003 07:11 AM |
Internal Mixer again (sorry, but help please!!!) | Musashi | Tips & Tricks | 1 | 03-30-2002 12:06 AM |
Internal Mixer again (sorry but help please) | Musashi | Pro Tools TDM Systems (Mac) | 0 | 03-29-2002 05:27 AM |
