Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-21-2016, 07:49 AM
jeam25's Avatar
jeam25 jeam25 is offline
Default CCTV system suggestion needed
Hi !
I going to eliminate my studio glass to have more acoustic treatment . I want some suggestion for a monitoring system so i can see the the recording room trough a monitor or lcd tv . I know that with a regular cctv I will need a DVR . But what about computer surveillance cameras that operates trough the computer ? My question is because I don't know if their software affect PT performance . What options I have ?
Thanks !!
Mac M1 Studio Ultra - Sonoma Beta OS
Avid Carbon Interface
Protools Ultimate
Old 04-21-2016, 12:20 PM
Default Re: CCTV system suggestion needed
In my old studio, the vocal booth and drum booth had no sight lines, so I used security cameras in both rooms(BNC video output) and at the other end(the screens), I used video-VGA adapters(around $40) and some old 4:3 computer screens(19"). Mounting the screens on some adjustable wall mounts kept things tidy(the VGA adapters were velcro'd to the backs of the screens).
In my current studio, I bought a modest surveillance package with 4 cameras. I use a computer monitor(again, an old 19" display) but it also has an HDMI output(50' HDMI cables are available on the web for less than $50). You could easily adapt this to your needs too, but honestly, the "home run" of 1 camera to 1 screen(via the adapter) works great. I hung the screens above face level, with the cameras right underneath.
Old 04-21-2016, 12:33 PM
jeam25's Avatar
Hi Albee thank you !
Do you use a DVR for them ? Or your DAW ?
Protools Ultimate
Old 04-21-2016, 12:58 PM
mjslakeridge's Avatar
mjslakeridge mjslakeridge is offline
I use 2 IP cameras that can be hooked up using ethernet cable or wireless using the WIFI signal of my modem/router. I happen to have Foscam Model: FI8918W from about 4 years ago, but I wouldn't recommend them because the setup (software side) isn't easy. I think there are more modern plug and play IP cameras out there now. I do not use my DAW to view the cameras, I have my everyday Windows 8 computer in the control room also. They can also be viewed on a smartphone or tablet over WIFI.
The wireless connection is ideal in my situation because you can move them around, depending on what you are tracking (drum booth, vocal booth, main studio). You can get 2-way audio through the built in speaker and mic in the cameras, but we don't use that since we have a good headphone monitoring and talkback setup (Furman ethernet based system)
"Whiskey Bottle...Brand New Car...Oak Tree You're in my Way" RVZ
Digi 002 rack , Command 8, Behringer ADA 8000, Tascam M-320B Mixer, Alesis Monitor Two Speakers, Vintage and Modern Tube Amps, Fender American Strat, 1973 Gibson SB-450 Bass, Epiphone Les Paul Traditional Pro, Roland W-30 Keyboard, Preimier XPK Fusion Drum Kit.
Old 04-21-2016, 07:13 PM
I use a DVR for security, but the cameras and screens were simply so players could see each other. Now a package with a DVR might do the trick for you, but 2 things matter; 1-you don't need to record anything(although you might want to), and 2-remember that you want to be able to run a screen in each separate room, so make sure whatever system you buy can handle that(maybe take an HDMI output, feed that to a 4-way splitter, feed out to 2/3/4 decent-sized TV's and show all 4 cameras on all screens
Old 04-22-2016, 08:26 AM
john1192 john1192 is offline
remember this .. if it is Digital you may have latency in the video feeds .. processing time .. so, analog camera will give you a more immediate picture .. especially if people are looking at each other via different cameras ...
i worked in a studio that used the consumer security cameras through a 4 way (quad split) and there was too much processing time to play together .. we used for just watching the drummer in the drum booth ..
cheers and hopes this helps a little .. i did not see anyone mention this yet ...
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
More system memory needed for DAE -6047 [email protected] Windows 0 11-06-2012 05:19 AM
Help needed - cannot upgrade 7.4 HD system to PT9 TDM? sg_57 Pro Tools TDM Systems (Mac) 9 01-13-2012 10:10 AM
Help needed with 'dinosaur' of a TDM system springthing Pro Tools TDM Systems (Mac) 27 10-13-2011 07:03 PM
SUGGESTION: Pro Tools Plug-in Management System like Firefox Add-Ons moogboy100 Pro Tools 9 7 07-15-2011 06:22 AM
What's the min needed for a decent TDM system? David Fisher Pro Tools TDM Systems (Mac) 4 09-25-2002 08:11 PM
