Recording Internal effects Latency issues ..
Hey Everyone Please Advise if you can !.. In a urgent session and need Answers
I have a new Westmere 8 core Mac 2.4 . PT 9.0.1 Digi 003 Rack I am trying to record effects onto the actual track so i set up a Aux Return ..input Analog 1 my mic - Then send to Bus 1 and Return to Track 1 input Bus1 There is a delay regardless of what buffer setting i have gone all the way down to 32 and still some latency issues on the track with NO PLUGINS ANYWHERE In comparison to when i just record enable track 1 and set it to low record compensation then the mic sounds fine. However I do need to be able to track certain effects straight away as opposed to inserting them later. Does everyone have this issue with latecny and is there a workaround as there is now way i can run my system at 32 all the time .. PLease help Thanks |
Re: Recording Internal effects Latency issues ..
I would think a round trip like that will always have delay.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
I also found this as soon as I got to pt9. It looks like it only happens with a mono sub path in a stereo aux. Is that the case for you? Either way, with pt9, turn on delay compensation or create mono busses and you'll be fine. I swear it never happened prior to pt9 but some people say it's always been like this.
-Ryan Young •2019 Mac Pro 3.5 GHz 8-Core Intel Xeon W - 48 GB 2666 MHz DDR4 (OS 10.15.5) •HD Native PCIe, HD Omni, 192 I/o, Pro Tools Ultimate •Avid S3 + Dock •Blackmagic Intensity Pro (HDMI) •5.1 Room with JBL LSR4300 series
Does ADC work on a recording like this? I thought it was for playback.
Hi thanks none os these really helps I wanna be able to record with verb and distortion on the tracks ... Surely there must be a way to do this and monitor through headphones without latency
Please get back thanks ... I have already tried making a mono bus and still no joy |
A quick way to use it for recording would be to set the track's output to a bus and add the effects to that bus. I usually do that when people want to record with effects, always runs smoothly.
Recording into Logic Pro 9 via Protools-Latency issues | quefijo | Pro Tools 10 | 0 | 08-22-2012 05:47 PM |
Using rack external effects as inserts latency issues | willl3 | Windows | 2 | 03-19-2012 10:37 AM |
Profire2626IO Recording Latency Issues | jimmyz | Pro Tools M-Powered (Mac) | 0 | 05-07-2009 06:40 AM |
Digi 002 & Recording Latency Issues. | Monaco | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 01-11-2008 05:14 PM |
Latency issues in headphones and recording | BretFarewell | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 03-21-2005 11:15 AM |
