Old 05-02-2022, 12:35 AM
Shefi Shefi is offline
Default PT 2022.4 Audio Suite- pitch shift
Pro Tools 2022.4 - After using the Audio Suite "pitch shift" the processed file does not replace the region selected for the edit but goes to the Clips list.
Is this a Bug? Is this a New idea?
Shefi Yishai
Old 05-02-2022, 12:44 AM
BScout BScout is offline
Default Re: PT 2022.4 Audio Suite- pitch shift
Check you Audiosuite window (of the plugin.) There is an option to do what you describe. And it persists. But default is edit window.
Old 05-02-2022, 01:13 AM
Thanks!
I know there is an option to select "USE IN PLAYLIST" But before 2024.4 I never had to select it. It seems that after the update I had to manually select "USE IN PLAYLIST" in order to replace the original region with the edited one.
Shefi Yishai
Audio Suite Pitch Shift himynameisdustin macOS 11 11-09-2015 05:01 AM
Any workaround way of automating the pitch knob in audio suite time shift? DBK Getting Started 3 06-25-2015 02:23 AM
Pitch Shift Audio Suite problems wasabi Pro Tools TDM Systems (Mac) 5 04-24-2007 08:07 AM
Audio suite pitch shift makes digital garble Arts Academy Hel Pro Tools TDM Systems (Mac) 4 05-15-2005 09:54 AM
Audio Suite Pitch Shift plug in sir d 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-08-2005 09:40 PM
