Old 07-02-2014, 08:54 PM
Nathan W. Nathan W. is offline
Default Sudden Disk Usage Spikes to 50-70%
I'm getting sudden random disk usage spies to 50%-70% and sometimes where protools gives me an error saying it can't access my drive fast enough. It's normally 3-7% then boom, huge spike, then sudden drop off. Anybody have an idea what's causing this? PT11.1.2 OSX iMac using a SSD USB 3.0 drive. Could time machine be responsible for this? Happens when I'm recording / printing my mixes down.
Old 07-02-2014, 09:03 PM
Default Re: Sudden Disk Usage Spikes to 50-70%
Clear information helps. What exact mode/date code iMac? CPU and memory specs? What OS X Version? What exact Pro Tools error number are you getting?
What is the exact make/model/spec/capacity of the USB3 SSD audio/session drive? How full is the drive? Is there anything else using that drive? There should be no VI samples, plugins or apps on it, just audio/session files.
What are all your playback engine settings?
What CPU meter are you looking at?
Have you fully optimized your system? Done every last thing? Time Machine should be disabled. I would also disable spotlight (mark the audio/session volume private, in fact mark all drives as private while debugging) even though Avid say it is OK to enable it for Pro Tools 11.
Old 07-02-2014, 10:51 PM
iMac Late 2013 Mavericks 10.9.4
16 GB Ram
Playback 1024 Samples
Disk Playback Normal
LaCie Rugged 256 GB SSD (using USB 3.0)
Looking at the System Usage meter. The drive is clear of everything except ProTools session files.
Had time machine on, leaving on but excluding my SSD drive I was using. Also turning off spot line for the 256 drive.
___
No random disk spikes anymore hurray!
Old 07-02-2014, 11:33 PM
That was easy.
I'd tend to turn off time machine all together/only enable it when not using the system.
Can't bounce to disk all of a sudden. Any suggestions? songwritersoul Pro Tools 11 4 06-30-2014 08:46 PM
iLok causing CPU/disk spikes Richard901 macOS 2 10-14-2012 01:44 AM
What would normal disk usage considered to be in the usage window? Digitopian 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 09-08-2009 09:50 PM
Pro Tools System Usage CPU monitor Spikes but not Windows Sherbert99 Pro Tools M-Powered (Win) 0 05-28-2008 07:18 PM
Help understanding CPU Usage, RAM, Disk Usage... Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 02-03-2006 07:41 PM
