Recording through Native Plugs in HDX
Hi guys,
I'm running an HDX-system. I used to record my guitars live from an amp or via 11r. From time to time I'd love to use Guitar Rig, but it just doesn't work, as (of course) PT bypasses all native plugs in the channel as soon as I record enable it. Is there an option to make it work or some kind of work around ?
PT 2018.12, Mac Pro, HDX, S3. |
Re: Recording through Native Plugs in HDX
Use an aux track as the input track then route to an audio track for recording. Put your plugs on the aux input. When the audio tracks are record enabled the aux plugs stay active.
To sum up, HDX with DSP plugins, or HDN with native plugins, is reasonable latency-free, and works very well. Clients don't complain. Anything else (including tracking with HDX with native plugins) is a compromise, from a latency-tracking scenario. Mixing is another story. But if you are trying to record and MONITOR latency-free, HDX with native plugins in the monitor path is not gonna give you that. |
The only reason to go through a plugin at the recording stage would be to print it. Otherwise do it after the fact. You either want that sound or you don't. Personally I would never want to track through a plug but the implication is that the desired sound is in the plugs.
You could do the reverse and run the output of an audio track, record enabled and all, to an aux with plugs for monitoring. Same idea, different execution. |
The OP is talking about recording guitar using an amp sim. The DI guitar signal for sure wouldn't be very awesome to play to. There are also many other reasons to need to record through a plugin, FX, modulation, distortion etc..
Just track using the Eleven Rack to drive the monitor. There really are not good enough sims there to montior with? You can always reamp that later with any other amp sim plugin.
You also have AAX-DSP options for Eleven plugins, softtube and maybe others. |
Native Instrument Plugs vs Stock PT-10 Plugs | PatriotsBiker | AAX Plug-ins | 8 | 02-04-2013 11:19 AM |
HD Native and ReVibe (amongst other TDM only plugs) | paranerd | Pro Tools HDX & HD Native Systems (Mac) | 9 | 01-14-2012 11:34 AM |
Non native instrument plugs? | RhodesB3 | Pro Tools TDM Systems (Mac) | 4 | 08-03-2009 10:02 PM |
Mix & Match HD and native plugs on HD2? | buckaroo | Pro Tools TDM Systems (Mac) | 4 | 01-14-2009 07:09 AM |
MCDSP native plugs! | cary chilton | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 01-30-2007 07:10 AM |
