Old 06-05-2014, 07:21 PM
jimjenkins123 jimjenkins123 is offline
Default PT 10/11 HDX in Magma EB3T and Mac Mini
My system consists of:
PT HDX with latest firmware / Mac Mini running OSX 10.9.3 / Magma Expansion Chassis 3T
My status is:
HDX hardware shows up in the Coreaudio Manager and HW setup.
HDX hardware shows up in the mac system prefs.
HDX hardware shows up in the Audio Midi Setup app (with 64in/64out)
My issue is:
Once PT 10 or 11 is started, the HDX hardware is not available as a playback engine. When hardware tab is selected and audio midi setup is launched, the PT hardware appears suddenly to have 0in/0out.
I have tried trashing prefs, re-installing the HD drivers etc. Nothing seems to work to make the HDX hardware show up int he playback engine dialog.
Please help.
Old 06-05-2014, 10:04 PM
Nathan W. Nathan W. is offline
Default Re: PT 10/11 HDX in Magma EB3T and Mac Mini
Make sure your Mavericks sound is set to internal not ProTools.
Old 06-06-2014, 10:36 AM
I tried that. Did not work. HDX still is not available as a playback engine in both PT 10 and PT 11 despite showing up in both AMS and Avie Coreaudio manager.
Any help would be greatly appreciated.
Old 06-06-2014, 01:15 PM
nst7 nst7 is offline
I'm a little confused here. If you're using the HDX system for Protools, it is irrelevant whether or not it shows up in Audio Midi setup, as that has nothing to do with it. That makes it sound like maybe you are trying to use it simultaneously with something else, which is not possible.
I don't know if you've tried this, but try holding down the "N" key as you launch Protools. See if it then shows up as an option.
Assuming this works, you won't have to hold down the "N" key normally. Only when you go to a new computer, reinstall Protools, or reformat your system hard drive.
Old 06-06-2014, 01:26 PM
Yes - I guess AMS doesn't mater. . .but I checked there just to see that the hardware was recognized by the computer. Plus that is where the aggregate I/O is configured.
I tried holding down N, and it is still not an option.
Not sure what to do here short of a clean install. . .which seems like overkill since this is a system that a lot of people are using successfully.
Mike496's Avatar
Mike496 Mike496 is offline
Digi test, check your firmware.
Old 06-06-2014, 02:03 PM
Firmware is up to date. All Digitests passed.
No idea whats going on here.
Old 06-22-2014, 04:43 PM
Mike496's Avatar
I did it again. Just installed an SSD opened PT and HDX was a no go. I forgot to download the drivers!
Mac Mini, Mac Mini Server, or iMac? fretcruiser macOS 5 06-17-2012 10:37 PM
If HDX is N and Westmere only, we can't use it in Magma's box with a Mac Mini? Rockman413 Pro Tools HDX & HD Native Systems (Mac) 2 11-26-2011 07:53 AM
Any knowledge of this Magma....magma p7rb 64 bit ? Sixstringer7 Pro Tools TDM Systems (Mac) 5 04-02-2011 02:39 PM
Am I Missing Something?! Mbox Mini, Mac Mini, Shockingly Bad gunark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 12-07-2010 12:58 PM
Any Mbox2 Mini/MAC Mini Intel Users? Need help with Reason Mbox2digi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 07-31-2007 07:37 AM
