Old 03-27-2013, 05:57 PM
mr xy mr xy is offline
Default Avid Tech - Please confirm/ deny: Sidechain inputs are not delay compensated in PT10?
I see they are on HDX systems now (as an option)- is there hope for this been implemented on non- HDX PT rigs?
Old 03-29-2013, 04:03 PM
Default Re: Please confirm/ deny: Sidechain inputs are not delay compensated in PT10?
Old 03-30-2013, 03:12 AM
JFreak's Avatar
JFreak JFreak is offline
I have always had the impression that sidechain inputs have been delay compensated to begin with. Because what are they? A send/buss that is seen as input somewhere. Sends and busses have been delay compensated from day one, as far as I know. I would happily stand corrected if someone has real info.
Janne
Old 03-30-2013, 10:51 AM
well they aren't in my system. I'm not sure if they used to be or not - it's not something I used to do as much, and I'm using more high-latency plugs than i used to, which makes the problem very apparent. I would love to know if this is something system specific or if it's a basic shortcoming of the delay comp.
I tend to think the latter, given that in the latest PT update has added a HDX only preference to compensate side-chains.
Could an Avid/digi person please clarify?
Old 03-31-2013, 05:05 PM
nst7 nst7 is offline
Where is the option located in the HDX menu?
I'd like to test this on my HD Native system, but I don't know much about side chaining. What would be a simple way to test this? Besides stock plugins, I have Waves Diamond and C6, if anything from there would help.
Old 03-31-2013, 06:06 PM
Top Jimmy's Avatar
Default Re: Avid Tech - Please confirm/ deny: Sidechain inputs are not delay compensated in P
Depending on where the side chain source is coming from and where it is going to, it could very well be way out of time. And there is no way to compensate for this as there is no way to send the future into the past. This has always been a big weakness in Pro Tools, and it is only exacerbated by the active delay method of ADC employed by PT.
The only way to get a completely reliable side chain source is to copy the track you want to use as the source and slip the regions forward in time to get.the required accuracy. This track is only used for the side chaining and doesn't end up in the mix.
Buttdialed by me & Tapatalk
James Cadwallader
Old 03-31-2013, 07:02 PM
DUCHUNTER DUCHUNTER is offline
Really? I've not noticed this with C6 and HD Accel.
Old 03-31-2013, 08:23 PM
Top Jimmy's Avatar
Possibly because you haven't used any plugs with large processing delays on either of the tracks involved in the side chaining? As long as you're only using plugs with little to no delay, there isn't so much of a problem.
James Cadwallader
Old 04-01-2013, 02:21 PM
from the the 10.3.4 read me pdf:
Automatic Delay Compensation
Delay Compensation may now be enabled for plug-in sidechains in the Operation preferences. (HDX hardware-accelerated
systems only).
i really hope they add this to native systems too.
Old 04-01-2013, 04:50 PM
Top Jimmy's Avatar
systems only).
Hot dang! I need to pay more attention to those read me files.
Even so, I bet I could break it.
James Cadwallader
PT11 - sidechain inputs not delay compensated on non-HDX systems mr xy Pro Tools 11 6 02-04-2015 12:25 PM
DTS Confirm/Deny 8.04cs2 timeline recording late? MikeLip 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 10-20-2010 06:20 AM
Is Automation delay compensated via ADC? made Pro Tools TDM Systems (Mac) 4 04-11-2010 03:19 AM
Is Automation Delay Compensated? Trailerman Tips & Tricks 6 02-17-2005 12:03 PM
Question on 192 i/o - I want to confirm/deny rumor Jaylaca Pro Tools TDM Systems (Mac) 15 10-20-2004 09:53 PM
