motherboard questions
I'm looking for a motherboard to run an HD-3. Ideally it would have lots of CPU power left over for RTAS plug-ins. It needs three PCI slots of the same kind, so if I get a PCI-x it has to have three PCI-x slos operating at 133 MHz, yes? Or, if I get a PCI-e Pro Tools system, then the motherboard has to have 3 PCI-e slots of the same kind, like, three 8x slots let's say. Am I correct so far or is there some slop in the "uniformity" requirement?
Then - scanning the availabe motherboards from various companies, it appears that getting ANY motherboad with three idential backplane connectors is very difficult these days! I found one from SuperMicro that has 6 PCI-x slots, three of which are 133 MHz. That's all, just the one, and the backplanes from most manufacturers look like a mish-mosh of "one of each" in terms of connectors and card types. First question is, what kinds of motherboards are you using for HD-3's? And second question is, are there any other possibilities? Like, is there some kind of expansion bridge that turns a single PCI-e connection into an 8x PCI-x expansion chassis, or some such thing? I want dual CPU's if I can get them (as many cores as possible), and plenty of RAM - so what are the hot motherboards these days? (ps Fry's doesn't even stock anything with two sockets anymore.... sigh...) |
Re: motherboard questions
You can use standard length PCI slots for your full length cards.
PCI-e compatibility is for x4 slots I believe... which means you can use a x4, x8, or x16 slot and mix them for the three cards.
Pro tools HD 9 - HD3 setup w/96 IO AMD 3.81GHZ Phenom II X6 CPU - 8GB Ram - Win7 64-bit Focusrite Voicemaster Pro Presonus StudioLive 16 Channel Mixer Digimax D8 8-Channel Preamp Command 8 Vocal and Instrument Recording/Live PTHD Mixing |
Any motherboard with any size of slot (1x, 4x, 8x, 16x) will work with the cards, as the cards only use 1x. Every single type of PCIe slot can run electrically at lower speeds. Thats the beauty of PCIe.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
http://www.newegg.com/Product/Produc...82E16813121410
http://www.newegg.com/Product/Produc...82E16813121407 and If i were building a new box today i would most likley get into this one http://www.evga.com/products/moreInf...%20Family&sw=5 http://www.evga.com/articles/00537/ |
Hi - thanks for this tidbit. But what are the extra pins for? And don't most of the connectors have fat edges so they (deliberately) won't fit into the slot thingie?
Cost on that, for a single processor, is about 3500, and for two processors maybe 5 grand and change. (5680's with a minimal configuraion, only three of the DDR slots populated on each side, firewire card, dual monitor video, and a couple of nice big drives). Oh and a nice big power supply. Plus you could multi-boot it and have a "safe mode" ProTools that you can always access and an "experimental" ProTools booting on the same machine with access to the same projects. Hm, this has possibilities. And blazingly fast CPU's make it a natural for M-Powered too, so why not add an extra partition for that too? Ha ha - if you're smart you'll never have to unplug iLoks. Ha ha. :) |
I use the Intel H55HC motherboard with 3 adjacent PCI slots. You will need to add a firewire card, and you'll need a video card for use with Windows 7. Runs Pro Tools great, $99.
http://www.tigerdirect.com/applicati...7BBTkwCjCECjCE |
I have a pal that does Video editing and he built three weeks ago a monster box out of that EVGA board and for test I took my PCIe cards and interface over to his place and installed PT and it was fine. Loaded every gosh darn RTAS we could and tried to bring the box to its knees and could not.
Nope.. the extra pins are for more bandwidth. Check the following from Wikipedia on PCI vs PCI-X: Quote:
Motherboard and CPU under $350 | djmichaelwenz | Windows | 27 | 02-19-2012 01:35 AM |
Motherboard help | Carl Fuehrer | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 11-18-2002 01:52 AM |
New motherboard / now what? | gabadilla | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 12-02-2001 05:54 PM |
Motherboard questions - Please Help!! | Soul Shaker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-24-2000 09:58 AM |
Urgent questions regarding Motherboard/CPU | musicfest | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 07-11-2000 12:24 AM |
