#6321
Re: i7 Builds - Specs and Results
www.pro-tools-pc.com
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#6322
Hello,
If I may ask, what x99 motherboard has the highest compatibility for the accessories you guys use in here? I have a high level of hardware understanding except I am not a pro tools user, instead am building a DAW system for someone who pointed me to this thread. We were planning on using the asus x99-a but the firewire pci-e support is an interesting concern...although it may not be an issue for the person I am building for as they did not mention firewire was needed. Please advise as my original recommendation was an asus x99-e ws usb3.1 but was a bit out of budget and the matx version would have limited the ram a bit. Thanks |
#6323
New system finally here, installing Pro tools...
Thanks again for all your help/advice.
Pro tools 11 Win7 64bit | i7-6700k | Gigabyte B150M | Corsair Vengeance 16GB DDR3-1600 RAM | Gigabyte N610SL-2GL | 2 x WD Black HDD | Samsung 850 Pro SSD | Corsair CS750M 750W | Corsair H75 | Fractal Design Define R5 | Focusrite Scarlet 6i6 | Eleven rack | Behringer Eurorack MX1604A | Boss BR1200 | MPC 2000 XL | Roland MC303 | Various Mics and instruments | Asus M51VR Laptop |
#6324
Ok I had to share to help other builders, I have learned so much trying to get a stable system that would not freeze, and I finally did it using a i7 5960x, 64 GB ram. Here is my Sandra Report in case anyone would like to know. I think a big part of it too was upgrading from Pro Tools 10 to Pro Tools 12 because of plug ins running at 64 bit. ( I am not a computer geek, but somewhat knowledgeable ) So far I can run multi plug ins like Waves Butch Vig Vocals, Guitar rig 5, Studio Drummer, EZDrummer, Kontakt 5, Komplete Kontrol and multiple reverbs, delays ect. and so far I have had not even a hic up, it has been as stable as a rock. Also Pro Tools 12 has the new commit feature which quickly bounces down all the plug ins on one track to a new track to free up resources, but I haven't even had to do that yet. Here is my Sandra Report,
SiSoftware Sandra ID Host Name : WOOD-PC Workgroup : WORKGROUP Computer Model : MSI MS-7885 Serial Number : To be fille*********** Chassis : MSI Desktop Mainboard : MSI X99A SLI PLUS(MS-7885) Serial Number : To be fille*********** BIOS : AMI (OEM) 1.80 03/20/2015 Intel vPro : 9.01.25.1005 Total Memory : 63.9GB DIMM DDR3 DDR4 Processors Processor : Intel(R) Core(TM) i7-5960X CPU @ 3.00GHz (8C 16T 3GHz, 3GHz IMC, 8x 256kB L2, 20MB L3) Socket/Slot : FC LGA2011 Chipset Memory Controller : MSI Xeon (Haswell-E) DMI2 100MHz Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 0 Target Address, Thermal & RAS Registers 100MHz, 4x 16GB DIMM DDR3 DDR4 2.13GHz 256-bit Memory Controller : Intel Xeon (Haswell-E) Integrated Memory Controller 1 Target Address, Thermal & RAS Registers 100MHz Memory Module(s) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Memory Module : G.Skill F4-2133C15-8GRR 8GB DDR4 PC4-17100U DDR4-2132 (15-15-15-36 4-52-17-6) Video System Monitor/Panel : AOC International 2770Vh1 (1920x1080, 27.0") Video Adapter : NVIDIA GeForce GTX 960 (8CU 1024SP SM5.0 1.18GHz/1.44GHz, 1MB L2, 2GB 7GHz 128-bit, PCIe 3.00 x16) Graphics Processor CUDA GP Processor : NVIDIA GeForce GTX 960 (1024SP 8C 1.18GHz/1.44GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit) OpenCL GP Processor : NVIDIA GeForce GTX 960 (1024SP 8C 1.18GHz/1.44GHz, 128kB L2, 2GB 6GHz/7GHz 128-bit) Compute Shader Processor : NVIDIA GeForce GTX 960 (1024SP 8C 1.18GHz/1.44GHz, 1MB L2, 2GB 6GHz/7GHz 128-bit) OpenGL Processor : GeForce GTX 960/PCIe/SSE2 (2GB) Storage Devices SSD2SC480G1CS1754D117-514 (480.1GB, SATA600, SSD) : 447GB (E:) Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) : 233GB (C:) WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) : 932GB (F:) Patriot Memory (4.1GB, USB2) : 4GB (G:) ASUS DRW-24F1ST c (2.6GB, SATA150, DVD+-RW, CD-RW, 512kB Cache) : 2GB (D:) Logical Storage Devices Pro Tools (E:) : 447GB (NTFS, 4kB) @ SSD2SC480G1CS1754D117-514 (480.1GB, SATA600, SSD) System Reserved : 100MB (NTFS, 4kB) @ Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) LIBRARY (F:) : 932GB (NTFS, 4kB) @ WDC WD10EZEX-00BN5A0 (1TB, SATA600, 3.5", 7200rpm) PATRIOT (G:) : 4GB (FAT32, 4kB) @ Patriot Memory (4.1GB, USB2) Hard Disk (C:) : 233GB (NTFS, 4kB) @ Samsung SSD 850 EVO 250GB (250GB, SATA600, SSD, SED) G71-MID2046 (D:) : 2GB (CDFS, 2kB, Read-Only) @ ASUS DRW-24F1ST c (2.6GB, SATA150, DVD+-RW, CD-RW, 512kB Cache) Peripherals LPC Hub Controller 1 : MSI Wellsburg LPC Controller Audio Device : MSI Wellsburg HD Audio Controller Audio Codec : Realtek Semi High Definition Audio Audio Device : MSI High Definition Audio Controller Audio Codec : nVidia 0072 Disk Controller : MSI Wellsburg sSATA Controller [AHCI mode] Disk Controller : MSI Wellsburg 6-Port SATA Controller [AHCI mode] USB Controller 1 : MSI Wellsburg USB xHCI Host Controller USB Controller 2 : MSI Wellsburg USB Enhanced Host Controller #2 USB Controller 3 : MSI Wellsburg USB Enhanced Host Controller #1 USB Controller 4 : MSI VL805 USB 3.0 Host Controller USB Controller 5 : MSI ASM1142 USB 3.1 Host Controller SMBus/i2c Controller 1 : Intel ICH SMBus SMBus/i2c Controller 2 : Intel SNB/IVB/HSW-E XMB Ch 0 SMBus SMBus/i2c Controller 3 : Intel SNB/IVB/HSW-E XMB Ch 1 SMBus Printers and Faxes Printer : Microsoft XPS Document Writer (600x600, Colour) Fax : Microsoft Shared Fax Driver (200x200) Printer : Canon MG5400 series Printer (Colour) Peripherals Media Player : Patriot Memory (3.82GB) Network Services Network Adapter : Intel(R) Ethernet Connection (2) I218-V (Ethernet, 100Mbps) Operating System Windows System : Microsoft Windows 7 Ultimate Media Center 6.01.7601 Service Pack 1 Platform Compliance : x64 |
#6325
Wow, GTX 960 seems like a whole lot of graphics horsepower just for Pro Tools. If you're using Adobe stuff (Media Converter, Premiere, After Effects) let me know how the GPU acceleration works for you.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
#6326
Anyone tried the new Samsung 950 Pro?
Looks like a beast, might have to try one out! Luckily my Mobo has M2 capability http://www.samsung.com/us/computer/ssd-pro I haven't looked back to see if discussion has already been had around this drive so apologies if it has.
Too much blood in my drugstream Motherboard: Gigabyte Z690 AERO D CPU: Intel Alder Lake Core i9-12900K CPU Cooler: Noctua NH-D15S RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz) Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples) 1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro) GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4 PSU: Corsair HX Series HX850 Platinim CASE: Fractal Define XL R2 PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII HD 96I/O |
#6327
Unfortunately not yet.
But I'm probably getting this disk along with a I7-5960X cpu for my new PT rig sometime next year. It shure does. 2500 MB/s read and 1500 MB/s write is impressive. It wasn't that long ago a disk with half the specs was 4 times as expensive as this. |
#6328
#6329
Is there another bottleneck in the system that will stop these drives from reaching these read/write times?
#6330
M.2 does use PCIe bandwidth. On systems where A lot of PCIe devices are used, the M.2 could be a problem or throttled from say a 4x slot to a 2x speed. Some motherboards will disable a specific PCIe slot when the M.2 is used as well. There is a lot of variables depending on the motherboard.
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
