Old 12-16-2004, 11:04 AM
jeronimo jeronimo is offline
Default How´s your UAD treating you?
I´m thinking about buying an UAD card to use w/ my G4 Dual 533 (512RAM) runing 6.4 LE w/ a 001, so I can have a bit more DSP power to work. What do you guys think about your UAD? Can you please post your setup (mac, digi hardware, software version and OS version) and your thoughts about the system?
Thanks!!!!
Think Diferente!
Old 12-17-2004, 04:04 AM
Default Re: How´s your UAD treating you?
Hey guys, I know many of you are using an UAD card w/ PT LE, help me out!
Think Diferente!
Old 12-17-2004, 11:08 AM
Tubz Tubz is offline
Not too good... It works and sounds good... until the UAD-cpu meter goes to about 30 - 35%, then it won't work anymore... But 'til then its ok. You will for sure could run a bit more then me because of your faster soundcard. But it takes a bit of your cpu too, so when you have an old machine... well, I don't know...
Tubz
Old 12-19-2004, 12:31 PM
mindseye mindseye is offline
are there any plug-in bundles that are comparable quality-wise to UAD that
work better in the PT LE environment, less taxing on the system??
Old 12-19-2004, 03:53 PM
They're the best I've heard, and I guess it runs a bit better with 002. With mbox... Hmmm, alot of cuemixing and bouncing going on...
Old 12-19-2004, 04:18 PM
pellefri pellefri is offline
The Uad-1 is fantastic, especially the comps. I went to logic actually because of the possibility to use UAD/Powercore plugs. Not having Delay compensation in LE made it too complicated for me. But there is a rumor about PTLE 7 having delay compensation.
Otherwise, check sonalkis plugs out... heard good about Firium/Eqium.. But you need the VST wrapper, a great addon from Fxpansion.com
Pelle
Old 12-19-2004, 04:21 PM
hi again,
forgot, the UAD/PC plugs consumes a lot!! of CPU power... could be better with PTLE 6.7, I'm still on 6.4.
This on a 2x2 G5, 1,5gb ram Digi 002
Pelle
Old 12-19-2004, 04:46 PM
mersisblue mersisblue is offline
hi again,
Pelle
yeah its almost as if someone doesnt want the two things to work together
I also switched o logic for the UAD and other reasons
Old 12-19-2004, 08:47 PM
so is there anything comparable to UAD that will work with 6.7 better than UAD
without having to switch to Logic?
Old 12-20-2004, 12:09 AM
........ you could buy a HD rig .
How is 9.0.3 treating you? Eric Lambert Pro Tools 9 20 06-21-2011 12:38 PM
Hows that 8.0.1 cs2 PPC upgrade treating you? studiojimi Pro Tools TDM Systems (Mac) 40 05-19-2010 10:01 AM
Sound Treating Secrets Zap Launcher General Discussion 12 10-26-2008 06:01 PM
OT-Treating MP3's mixerboy Tips & Tricks 1 02-12-2003 08:59 AM
treating a small room Ben Jenssen Tips & Tricks 3 05-22-2001 09:13 AM
