Old 05-27-2019, 05:49 AM
Cheesehead Cheesehead is offline
Default Re: automatic loudness correction that can handle split stems too?
I think I agree with Mike.
After all, f you have any kind of dynamic processing over your mix bus its not going to react the same if you put the same plugin over the stems unless you have some sort of side-chaining going on.
I'm happy if my stems are in the ballpark in terms of level.
Its going to get re-mixed to a certain extent anyway if they're used.
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Old 05-27-2019, 07:44 AM
lae777 lae777 is offline
This is exactly right.
What is the point of making the stems loudness compliant as well as the full mix?
If the stems are being used for foreign language dubbing then they will be re mixed.
If they are being used as separate entities (e.g. music stem for a trailer) they will be re mixed to spec anyway.
If they are being used to re version to another format (e.g. 5.1 to Atmos) they will be re mixed.
What possible reason is there for having the stems match the full mix loudness specs?
They just need to be close in relation to the full mix at loudness spec.
5,1 Mac Pro, 3.46 GHz Six Core Xeon, 48gb ram, Pro Tools Ultimate 2023.6, HD Native card, Avid 192io interface, Avid 96io, Intensity Pro video card, Radeon HD 7950 graphics card, Mac OS Monterey 12.6.7.
Old 05-27-2019, 07:50 AM
seanmccoy seanmccoy is offline
Yeah, from a practical standpoint this is the only thing that makes sense to me. In many situations both the FX and Music stems may be very, very light, and would have to be cranked up to ridiculous levels to meet specs on their own.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 05-27-2019, 07:55 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Dynamic control shouldn’t be achieved on a mixbus - it should be achieved by correct mixing at source level, maybe with some mastering help (refinement) at source group level,so that your stems are correct.
Having said that, deliverables are request lists made by idiots for idiots, often cut and pasted by those who do not understand. There are two approaches; a) give the fools what they ask for or b) explain what they should have and what will actually be useful.
The requirement for your stems to be compliant is meaningless as they are never transmitted. However, it is much easier to edit in and out of scenes if the levels off your stems bear some relationship to the mix - I.e don’t be putting the latest Waves Ultrasodamizer on your mix stem and expect to please anyone that has to reversion!
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 05-27-2019, 04:37 PM
To be fair we have wandered a bit off topic here.
Alexy didn't suggest he wanted his stems to be loudness compliant, that would be bonkers.
He wanted to be able to use something like Nugen LM Correct to apply the same processing to a stem as to a full mix, in order to keep the stem at the same relative level as the level corrected mix.
I can totally sympathize with that and I think it would be a useful feature in some circumstances.
  #16
Old 05-27-2019, 09:58 PM
its2loud its2loud is offline
“He wanted to be able to use something like Nugen LM Correct to apply the same processing to a stem as to a full mix, in order to keep the stem at the same relative level as the level corrected mix.”
Probably beating a dead horse here but this just isn’t technically the correct way to do this. I may be wrong but processes like LM Correct aren’t just adjusting overall gain level to make the output legal. I believe there are complex algorithms at work to make the mix compliant while keeping the adjustments relatively transparent.
If one’s mix is so out whack that they need LM Correct to make it to spec then I’m willing to speculate that that that person needs to start over with the mix. Not judging the OP here, just stating an opinion. Measure twice, cut once, deliver. With offline measuring and history graphs it’s not hard to know where to make the necessary adjments in the mix in order to make it deliverable. Stems and all.
  #17
Old 05-28-2019, 02:13 AM
Farhoof's Avatar
Farhoof Farhoof is offline
That's only the DynApt extension. LM Correct itself is just measurement and normalizing, without dynamics.
  #18
Old 05-28-2019, 11:49 AM
alexeymohr alexeymohr is offline
Wow this really got philosophical quickly! ;-)
Obviously we can wax poetic on the rationality or irrationality of a network or streaming service demanding that their split stems exactly equal the composite mix stem. But the fact is that many do.
Also indeed things like iZotope RX Loudness Control and LM-Correct are brute-force dumb normalizers, simply measuring for LKFS and then applying corrective global gain.
So it strikes me that given how straightforward that is, it really shouldn't be all that hard to have the plugin store the gain adjustment value that it determined and allow the same adjustment to be applied to subsequent clips. That's all this was about!
But thank you all for the discussion of the relevance of this; I always do wonder, when presented with a ridiculous spec, whether or not anyone is actually verifying these things upon receipt of the deliverables. That said, I also do my best to do exactly as any client asks, regardless of my opinion of how reasonable it is!
- Alexey Mohr
https://www.parkstreetpost.com
  #19
Old 05-29-2019, 05:18 AM
Good to know about LM Correct an others about their dumbness. I have not met one spec that wasn’t ridiculous, time consuming, and technically incorrect in some regard. It’s only gonna get worse with the new streaming services coming up.
  #20
Old 05-29-2019, 05:53 AM
Specs are like tech rejections, treat it like bridge or poker and their often poor opening gambit, to which you as the knowledgeable pro can easily outbid to their eventual advantage...
I love telling tech review peeps how stupid they are (nicely of course) and pointing out the absurdity of some cut and pasted tech spec...it’s all part of the game
cheers
BAFTA member
IPS member
HTML code is On
Loudness Correction Feature Films For TV cheney5 Post - Surround - Video 8 09-27-2016 05:32 AM
iZotope RX Loudness Control - Automatic Loudness Correction for Broadcast iZotopeInc AAX Plug-ins 0 05-21-2015 10:16 AM
CALM Acts Audio Loudness, Average Loudness, Program Loudness levels... help needed qr2r Post - Surround - Video 12 11-10-2011 01:41 AM
D-Control 32 split or no split? Don Geppert ICON & C|24 8 01-30-2007 10:15 AM
USB can't handle 48v? carvell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-22-2005 09:40 AM
