Dupicating and renaming large numbers of files.
I have a large number of bounced clips on a track, named ...
<old_filename_XXX_old_suffix.wav> ... where XXX is a sequential number. I need to duplicate these clips and then rename them ... <new_filename_XXX_new_suffix.wav> ... so the file names match the clip names. If I use Auto Rename from the Clip List Menu, that doesn't rename the source files. I can only think of a way to do this manually, which is impractical with 50+ clips, or outside of PT, in which case the clip names won't match the file names. Is there a sensible way to do this within PT?
PT2020.5.0 / HDN / HD Omni / MC Control / Intensity Pro / Catalina / 3.7 Quad core Intel Xeon ES (trashcan) MacPro / 12GB RAM Over 30yrs experience in pro-audio - mostly for picture. |
Re: Dupicating and renaming large numbers of files.
For duplicate, duplicate the track. On the duplicated track, select all the clips, go to audio suite and select the gain plugin, don't change any settings in the plugin but change "create continuous file" to "create individual files" and then hit render.
For renaming, use Batch file rename to rename all the clips (using the replace option) for both sides (file name, suffix; you'll have to do it twice.) Then you file rename (shift+command+r) for all of them (select them all first) and hit return after each pop-up window to rename shows up (make sure the "name clip and disk file" is set on the first one.) That will commit the clip name to the file name (if the clips are complete files.) That second step is tedious but at least it's just hitting return 50+ times. Hopefully you aren't on 12.4 still since batch file rename doesn't exist yet. In which case you'll need to do "auto rename" followed by the trick I suggested to commit the clip name to the file name.
Pro Tools Ult 2024.3.1, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire Max11 x 2, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.6 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
I'm currently on 12.8.1 and I think Batch is new in 12.8.2
With the exception of the Batch Rename, as opposed to Auto Rename, that's pretty much been my workflow. I've been using the AS Duplicate rather than Gain. Unfortunately the Auto Rename doesn't have the option to rename file in the same way Rename does it looks like I then need to double click on each clip and Rename individually, which is just too easy to miss a clip. #timetoupgrade
Renaming all Files... possible? | Picture Start | macOS | 11 | 05-18-2014 10:23 AM |
Dupicating Aux Settings for IEMs | bobcats | VENUE Live Sound Systems | 2 | 01-16-2012 12:52 PM |
Renaming Files | n3xus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-25-2005 01:12 AM |
problem with up/downloading large numbers of wavs | K.B. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 01-19-2005 04:50 PM |
Lost files and renaming files | GoneIndie | Pro Tools TDM Systems (Mac) | 2 | 01-13-2005 07:08 PM |
