Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
Old 09-06-2019, 05:46 PM
J.Andreas J.Andreas is offline
Default Click/tracks suddenly out of tempo?..
I've recorded a song for hours. Suddenly, the click and tracks don't allign, and I've been pulling my hair trying to figure out what the problem is.. Midi tracks seem to follow the click, but the audio tracks I've recorded to the click are suddenly all way off.. Even when I go back to backups the same problem appears.
Does anyone have a clue why this happened and what I can do to fix it? I've upgraded to Mojave and 2019.5 recently and I never had this happen before..
Old 09-06-2019, 06:41 PM
JFreak's Avatar
JFreak JFreak is online now
Default Re: Click/tracks suddenly out of tempo?..
Hi, welcome to the community
Click is based on bars/beats and audio is just samples. All the "tick" based tracks (MIDI) follow click by their nature but manipulating tempo on sample-based audio is another trick. Take a look at the Reference Guide. It is a lengthy one but has a good index.
Janne
Old 09-07-2019, 12:09 AM
Thanks for the answer. I understand that midi follows the click regardless of tempo when tick based and audio does not. I've read through the reference guide, but I still can't figure out how to get it synced again. I don't get why something (everything) recorded in 138 BPM in this case, suddenly doesn't follow the click at the same BPM. I haven't changed anything afaik. Just suddenly when I pressed play everything was bananas.
Forgive me if I'm slow, but is there any setting I'm missing?
Old 09-07-2019, 02:06 AM
JFreak's Avatar
You have probably tried Elastic Audio
Janne
Old 09-07-2019, 08:14 AM
Ben Jenssen's Avatar
Ben Jenssen Ben Jenssen is online now
Are the audio tracks late, early, slower, faster, have they changed pitch? Details, please.
Old 09-07-2019, 08:28 AM
I wonder if perhaps you either enabled or disabled the tempo ruler: check the little conductor icon in the midi controls in the transport bar.
http://www.richbreen.com
MacPro 5,1 Dual Hex, OS 10.12.6, PT 2018 HDX, Avid HD I/Os and Metric Halo ULN8, Avid C24.
Old 09-07-2019, 11:11 AM
midnightrambler midnightrambler is offline
Or have the audio tracks slid out of place? Have you tried “spot” to see if the original time stamp matches up to its current position? Apologies if this is barking up the wrong tree, not many details to go on.
Old 09-08-2019, 04:54 AM
No tracks are elastic audio enabled either unfortunately.. thanks for the tip anyway!
The audio tracks are the same pitch, same tempo but are late. Even the first part of the song where the clips are recorded from the very start, the wave forms are late. In other words, if I chop all audio up and move them manually a bit earlier they sync up.
Tried it both enabled and disabled, the problem persists. Thanks anyway for the contribution!
The tracks are at the same time stamp as original. It seems like the bars/beats have moved somehow..
Old 09-08-2019, 05:02 AM
JFreak's Avatar
Well then move it back! You can manipulate song start position
Janne
Old 09-08-2019, 05:21 AM
Aahhh I'm an idiot... Thank you!! Didn't realise you could do that. That did the trick. Again, thanks for the quick help, much appreciated!
Tracks suddenly turned gray [SOLVED] SigFriedChicken Pro Tools 12 9 09-20-2016 04:12 PM
PT suddenly made my tracks out of sync, help! babakdm Pro Tools M-Powered (Win) 0 02-08-2010 08:26 PM
Click at tempo changes One Track Music Pro Tools TDM Systems (Mac) 4 03-12-2006 07:13 AM
Click plugin suddenly not working...? Kling3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-30-2003 12:48 PM
Tempo click...? How? Help... : ) Jayson Torres 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 12-28-2002 12:27 AM
